12-01-2020, 02:47 PM | #1 |
Drives: 2020 Camaro SS 1LE Join Date: Nov 2020
Wheels and Tires
https://www.lethalperformance.com/vm...hoCAaoQAvD_BwE
https://www.lethalperformance.com/ho...BoCtR4QAvD_BwE So i have a 2020 Camaro SS 1LE and i was wondering if these wheels and tires will fit on my car due to bigger brakes with the 1LE package thanks for all your answers everything is helpful. |
12-01-2020, 03:53 PM | #2 |
Drives: ‘18 Camaro ZL1, ‘16 F150 S/C Coyote Join Date: Sep 2020
Neither link worked for me.
12-01-2020, 04:17 PM | #3 |
Drives: On Hiatus Join Date: Apr 2020
You are better off searching for wheels for a ZL1 since the calipers are the same. Offsets might not match and be wonky.
12-01-2020, 05:54 PM | #4 | |
'20 ZL1 1LE A10,
12-01-2020, 06:16 PM | #5 |
could you link me to some of these parts im new to getting into cars im trying to learn with everything that seems new thank you if you can and if not thanks for the advice i will try what to find what your saying thanks so much.
12-01-2020, 07:49 PM | #6 |
https://www.tirerack.com/tires/surve...ay.jsp?type=MP
Michelin Pilot Sport 4S - Tire Rack rates it the best. I've driven on it since it came out in 2016 or so. You basically have the same car as I have and I put a set of these on my 1LE in Sept. They're great in dry and wet above 40F. No ice and snow.
'20 ZL1 1LE A10,
03-21-2021, 02:49 PM | #7 | |
