11-27-2020, 11:00 PM | #1 |
Drives: 2016 2SS Summit White Join Date: May 2020
ARH Long Kit to NPP - 2016 SS
Bought my car that had a muffler delete to some tips. Going with the ARH long kit that can connect to the stock suitcase, currently in search of suitcase. But not sure on length of pipe needed after suitcase to be able to reach the mid pipe. Does anybody know this answer? or am I not making sense? thanks to all for the assist.
11-28-2020, 12:46 AM | #2 | |
Drives: 2017 2SS F1FTY Join Date: Feb 2020
11-28-2020, 08:21 AM | #3 | |
Drives: 2017 ZL1 6MT Join Date: Feb 2018
It was ok for a while but I wanted it a little louder so I recently removed my suitcase muffler and swapped it out with an AWE Touring Axle-Back. It's all good now 👍
2017 ZL1 Arctic Blue Metallic / 6MT / sunroof / NAV / PDR / RotoFab CAI + dry filter / Tony Mamo TB V1 / Skip Shift Eliminator / Hurst Short Throw Shifter / ZL1 floor mats / Dead Pedal cover (to match other pedals) / ARH Catless 1-7/8" headers + ARH X-pipe + AWE Touring Axle-Back / Diode Dynamic smoked side markers / American Authority tow hook
11-29-2020, 11:00 PM | #4 | |
Drives: 2018 Camaro SS/1LE Join Date: Jan 2018
2018 SS/1LE... summit white.. E85 ,Ported LT2 IM, Roto Fab, soler performance ported throttle body, secondary delete, mbrp axle back, tuned by CCNC
11-29-2020, 11:15 PM | #5 | |
I’m trying to figure out if it’s like an axle back install and u cut flush with rear suspension cross member.. knowing this will help me and op.. the pics are where mine is cut already
11-30-2020, 12:59 PM | #6 |
DVS510,
Note: Please refer to ARH instructions on where to cut. Having said that, this is where I cut my suitcase muffler at. Referencing the seam, it's 9" of pipe length. It was actually longer than that. But I rather cut long than short because it's easier to trim it down later versus adding length back on.
11-30-2020, 09:11 PM | #7 | |
12-01-2020, 09:30 PM | #8 |
SO, finished install on the long kit. It does require almost to the crimped section of the pipe. The ARH long kit is designed to slip over the NPP pipes w/ a clamp and does require longer than I would say most Axlebacks would require. That is, if you choose to not have to weld the unit to your NPP muffler case. I wanted a clean non welded finish in case I did one day move towards a different axle back system, so I found an NPP with the stock pipes up to the crimped section to then fit onto the ARH long kit.
In short, I found that if you're questioning the length of pipe you actually need, you're probably going to be short, as it does require most of that first section. I'll provide photos of where mine was cut to keep here as reference when lighting allows. I just wanted to thank all of you that helped with this discussion!! |
