Old 08-07-2022, 05:12 PM   #1
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
BANKS iDASH ALERTS ???
Hey team, wondering what some safe alert setting would be?
Not sure if these are good, wanted feedback…
Oil pressure below 25?
Maybe IAT3 above 150?
AFR below 11.8 ?
Thoughts? Can you share yours?
Should we set alerts for timing? Fuel rail pressures? Etc?
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC
Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank
ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE
BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi
Old 08-07-2022, 09:18 PM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
I have an iDash but have never set an alert except shift point/shift light. Just to save me the aggravation...what is the procedure? I have fuel rail pressure, MAT, ignition timing, rpm, boost, ethanol %, & speed visible.
Old 08-08-2022, 05:56 AM   #3
ZLE dude
Drives: '18 ZL1 1LE
I've got an alert set for 27psi oil pressure, because mine has always idled above 28 since new. Also, if you did AFR it would alert all the time due to coasting, or punching it and then letting off, it bounces around too much to make it an alarm on the idash I'd think. I monitor rpm, ethanol%, oil pressure, low side pressure, high side actual pressure, high side requested pressure, and timing advance.
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
ZLE dude is offline   Reply With Quote
Old 03-31-2024, 03:07 PM   #4
SOCAL.M6.ZLE
Anyone tracking lowside fuel pressure? I could not find it on the list :(
Old 03-31-2024, 03:32 PM   #5
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
I do, it is in there.
Just can't remeber where I found it, car is still in winter storage.
I set an alert if it goes too low, but it is a little anoying when you let off the gas it always comes on.
Edit: just looked at a picture of mine, it is under lift p.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE
Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel.
Elite tuning, results coming soon.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: Swisstyphoon1980
swisstyphoon is offline   Reply With Quote
Old 04-01-2024, 09:30 AM   #6
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1 - Modified All Bolt On's
I was never able to find the parameter for low side fuel pressure. But I have the following alerts set:
Oil pressure <28PSI
E/Alcohol % >60 (this will be changing after next tune)
Coolant Temp >195°
Speed >70MPH
2023 ZL1 A10 - CSP 2" Long Tube Headers by Stainless Works | Gesi G-Sport High Flow CATs | Stainless Works Legend NPP Axle Back | Roto-Fab Big Gulp | Kong NM103mm | Kong X-Port/Polish w/Griptech 2.3" Upper | Granatelli Malevolent Coil Packs | Granatelli 0 Ohm Plug Wires | Katech Valve Covers w/Coil Relocation | FI Interchillers Blower Spacer Plates | Mighty Mouse Mild | JMS Flex Fuel Booster | DSX Flex Fuel Kit | DSX Billet Lid | DMS 2gal Fender Tank | NT555R2's 305/285 | AEM w/b AFR | Banks iDash Data Monster | HPTuners MPVi3 Module and Licenses (ECU & CCM) | Remote Tuned by Ted at JRE
2023_ZL1-AUTO is online now   Reply With Quote
Old 04-01-2024, 10:18 AM   #7
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Injector Pulse width exceeding >6.0ms
low oil pressure <25psi
AFR >12.6
Would be worth having alerts for. I wouldn't worry about IAT 3, the ECU will pull timing as needed to keep it safe if tuned correctly. And if you are running Ethanol it's not really a factor unless you are going above 170. I know guys that run non intercooled turbo setups @ 25psi and don't pull anything until 200. They are on good E85 though.
2016 NFG 1SS A8
Options-2SS Leather/NPP
KingLT1 is online now   Reply With Quote
Old 04-01-2024, 02:35 PM   #8
SOCAL.M6.ZLE
AFR >12.6
Thanks King; I thought that timing was pulled at 130-140F on the LT4?
Perhaps that is without E?
Old 04-02-2024, 05:10 PM   #9
KingLT1
KingLT1's Avatar
Default is 132 which is conservative even on pump. On E blend can go about 40 degrees higher and still be safe.
2016 NFG 1SS A8
Old 04-02-2024, 05:17 PM   #10
SOCAL.M6.ZLE
oh.... OK. So that means the tuner has control of the temp at which timing is pulled?
Old 04-02-2024, 05:27 PM   #11
KingLT1
KingLT1's Avatar
Yep
2016 NFG 1SS A8
