Old 07-04-2022, 01:06 PM   #15
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Originally Posted by birdmanf16 View Post
I just measured. Brand new car....40 miles on it. 692 on the left front....and 686 (1/4" less) on the right passenger side. Interesting. I wonder if they are compensating for driver weight? Or just not exact on the height specs?
I am measuring with the camber set to Track. Assuming your new car is set to street camber. The street position would raise the car I would guess. I was assuming the Nurburgring setup was using the track position, but maybe not. It could be it needed to be "as sold" to qualify.
The driver side should be lower to account for driver weight ("picking up" a wheel lightens that corner). Your 6mm lower looks correct.
wakespeak is offline   Reply With Quote
Old 07-20-2022, 07:57 PM   #16
birdmanf16
birdmanf16's Avatar
Drives: 2022 Zl1 1lE
Send a message via MSN to birdmanf16 Send a message via Yahoo to birdmanf16
I believe the set up was on track camber set. They had no reason to put it on street. I am going to set it up on track and leave it be. I will check the height now that you mentioned it is possibly a different height...thanks for the heads up
2022 Camaro Zl1 1LE, e85, Roto Fab and tune
2020 Colorado ZR2 Dusk edition
2021 Mustang Mach e
birdmanf16 is offline   Reply With Quote
Old 07-20-2022, 08:04 PM   #17
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
I measured mine in track camber as well. Driver's side is 9.5mm lower in my case.
YouTube
Old 07-23-2022, 12:07 AM   #18
wakespeak
wakespeak's Avatar
So 10mm to round up, which is where I am lower in track camber as well. This says to me they ran stock ride height in street camber at Nurburgring. That was the rule as I recall, stock config, for production car times.
To add, with track use negative camber provides more even tire wear. In terms of grip, I had good times at street camber when I first got the car and ran COTA stock. This all depends on the track. I have run Nurburgring and I don't recall it being that hard on tight corners, except in a couple of brief sections.
I will leave my current alignment and (stock) ride heights for now.
