09-29-2018, 09:46 PM | #1 |
GRIM
Drives: 2015 Camaro Z/28 Join Date: May 2010
Z/28 clutch
So I have been reviewing the “14-15 Z’s clutch. During my search I have found very few chats that spoke in reference of the clutch assembly being anywhere in regards to heavy duty. The same as for the differential. I don’t seem to be able to find a particular topic on this question of interest. I have found on the GM sight the gear ratios and so forth but, nothing in detail of the Z/28’s clutch and or differential details as in HD, SD, equivalent to the ZL1 or is it exact comparison to the SS.
What are your thoughts, and or knowledge of this topic? Would anyone know if the Z28 clutch comes as a double clutch assembly? |
09-29-2018, 10:03 PM | #2 |
@MrRaZ28
It's not a double clutch.
Due to having the LS7, it has a LS7 clutch kit. https://www.gmpartsdirect.com/oem-pa...Y4LWdhcw%3D%3D |
09-30-2018, 08:28 AM | #3 |
GRIM
Z/28 clutch
Thank you, for your input. I did find this GM statement of description in a general outline of the Z/28, “TR6060 six-speed, is a close-ratio manual transmission. It has a combination of double-cone and triple-cone synchronizers on all gears. Double-cone synchronizers have two friction surfaces to affect gear acceleration and triple-cone synchronizers have three friction surfaces – the greater the friction surface, the easier the transmission is to shift”.
This certainly is substantial for the output of the 7.0 and what subsequent performance /purpose the Z was developed for. Also mentioned is that the “Z” comes with a close ratio shifter /short throw. Has anyone else installed and noticed a difference with the installation of a aftermarket short throw shifter? |
09-30-2018, 09:43 AM | #4 | |
Drives: 2015 Z/28 Black Join Date: Nov 2016
Clutch feels great to me. I am not particularly hard on it, but, after 13K miles, I have no complaint about the clutch, but, my Z/28 is a street car, I do not track it.
2015 Black Z/28
70 Chevelle SS396 01 M3, 88 Land Cruiser |
