07-09-2017, 08:51 PM | #57 |
Drives: '17 ZL1 Join Date: Jul 2016
Others have mentioned this already, but I just went over my car to prep it for Camaro Fest. My upper stabilizer link nuts were way loose! I was thinking most people were having trouble with the lowers. My lowers were fine, but the uppers were scary loose.
07-09-2017, 08:54 PM | #58 |
07-10-2017, 08:26 AM | #59 | |
I love crepes
07-10-2017, 09:33 AM | #60 |
Texas Military Forces
Drives: 2017 ZL1 Red Hot Auto Join Date: Jul 2009
Mine does the same thing. I already took it in for the service bulletin re-torqueing but guess I'll check the alignment too.
2017 Red Hot ZL1 Automatic (Sunroof, PDR & NAV)
2/10/2017 status: ordered 2/23/2017 status: 3100 TPW 3/6/2017 3/06/2017 status: 3400 TPW 3/6/2017 3/10/2017 built 4200 VIN# 1G1FK1R65H0193462 3/18/2017 Delivered to me! 2016 Camaro 2SS (wife's car) M228 Black Wheels 2010 Camaro SS (totalled by son) |
07-11-2017, 10:16 AM | #61 | |
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
Hopefully you found the solution to the problem.... |
07-11-2017, 10:28 AM | #62 |
I wouldn't describe it as really squirrelly, but I did notice the car not feeling quite as stable as it originally did while doing some spirited driving around traffic circles.
I haven't driven it since I tightened the nuts, but I can't imagine it won't be at least a little better. Sorry, I don't have pics. It would have been tough to see, but both sides were about 3-4 full turns from being torqued properly. |
07-11-2017, 11:07 AM | #63 |
Drives: 18 ZL1 A10 Join Date: Nov 2008
I ordered nord lock washers for mine
ZL1::J-E-T-S JETS JETS JETS |
07-11-2017, 11:11 AM | #64 |
Drives: 2017 Camaro ZL1 Join Date: May 2017
You sure you didn't accidentally push the "Mustang Mode" button? Could happen to anyone...
2017 Black ZL1 6MT
07-14-2017, 09:45 PM | #65 |
Drives: NFG17ZL1 Join Date: Jul 2017
First post, first Camaro, similar issue. My '09 CTS-V with more power, less tire and older technology was much more planted. Must be all the Texas cars... I think my swaybar links are loose and I will be taking it to the dealer to have it looked at. Hope it is minor and a quick easy fix. Otherwise I have little confidence in a tech locating and fixing. Maybe I need to be more optimistic.
07-15-2017, 06:06 AM | #66 |
Thank you Al Oppenheiser!
07-16-2017, 09:29 PM | #67 |
...Any input/answers from the Fest?....
07-16-2017, 10:12 PM | #68 | |
Drives: Duramax Join Date: May 2017
Just sayin |
07-17-2017, 04:18 AM | #69 |
Drives: '22 Silverado 2500HD Duramax LTZ Join Date: Dec 2015
^^^This^^^
If you mess with any configurations of the car the balance will be affected..... tire pressures are very important.... lowering springs and other modifications can dramatically change the feel of this car..... the way it was designed and intended....... Mine is completely stock and I have no ill effects of any kind......
07-20-2017, 06:16 PM | #70 |
Case closed?...Problem solved?.....
