08-10-2018, 04:40 PM | #1 |
Drives: 2017 ZL1 Coupe A10 Join Date: Aug 2018
2017 Rear bumper cover question
Hello. I have a 2017 ZL1 and someone tapped the back corner of the rear bumper. Only part damaged is the cover the license plate goes on, lower part is fine. Is the ZL1 cover the same as any other 2017 Camaro? Having trouble pulling one up online specifically for a ZL1. Any info appreciated, thanks!
08-10-2018, 05:25 PM | #2 |
Drives: 2017 Camaro 1SS Convertible Join Date: Jul 2018
Most likely if it's light damage a good quality body shop can fix it up for you like it never happened. For a lot less then what a OEM bumper plus paint would cost. Wish I had more info for you but that's all I've got.
17' Camaro 1SS Vert - Plastidip for 50 Hp gain.
08-10-2018, 07:39 PM | #3 |
Drives: 2018 Camaro 1SS/1LE Join Date: Feb 2015
Pretty sure the cover itself is the same. The ZL1 just has a different diffuser.
08-10-2018, 09:24 PM | #4 |
Thanks for the replies! Body shop friend is trying to fix it, just curious as worst case scenario if I need a new bumper cover if they are all interchangeable. Thanks
