Old 08-13-2018, 08:44 PM   #197
C7 Carbon
C7 Carbon's Avatar
Drives: Camaro
PMs replied
C7 Carbon is offline
Old 08-14-2018, 08:16 AM   #198
SilverSurfer Fifty
Drives: 2017 Camaro SS - gone
Got mine installed last night
I was able to install the spoiler last night. The main spoiler part did not align completely with the holes in my trunk. This resulted in the spolier being offset by a few millimeters to the left from center. I have to decide if I widen the trunk mounting holes to the right by couple of millimeters to adjust, or ask for a replacement.
It was dark when I finished, so I will take more pics today.
Everything was packed very well and the quality of the materials seems great. The only issue is the slight miss alignment. Very easy install. Hopefully I will be able to make slight adjustments to the mounting holes.
2017 2SS, Silver Ice Metallic
Last edited by SilverSurfer Fifty; 08-14-2018 at 08:20 AM. Reason: Grammar and pictures
SilverSurfer Fifty is offline
Old 08-14-2018, 09:12 AM   #199
cleoent
cleoent's Avatar
Drives: 16' Camaro E-Force SS
That's the same as mine. I think that's just how they fit.
Leo
2016 e-Force 2SS
Instagram @cleoent
cleoent is offline
Old 08-14-2018, 09:13 AM   #200
cleoent
cleoent's Avatar
Btw. It looks great!
Leo
2016 e-Force 2SS
Instagram @cleoent
cleoent is offline
Old 08-14-2018, 09:18 AM   #201
ss2fast4u
2018 Camaro 1ss M6
Drives: 2018 Camaro 1SS M6/ LT4 SC
Im holding off waiting for the wicker bill version but I starting to get antsy lol
ss2fast4u is offline
Old 08-14-2018, 06:07 PM   #202
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Looks great! What's the height from the deck to the top of the spoiler?
carguy55 is offline
Old 08-14-2018, 06:25 PM   #203
SilverSurfer Fifty
Thank you. Yours looks great also. Love the blue.
Old 08-14-2018, 06:50 PM   #204
V8Addict
V8Addict's Avatar
Drives: 2016 2SS
Same as mine also. I think its the left mounting studs that's causing the problem and doesn't align perfectly with the factory holes, at least it was with mine. I had to tap on the upper spoiler surface for it to slide down into the holes (the right and middle hole were fine).
2016 Hyper Blue 2SS, A8, NPP, MRC
V8Addict is offline
Old 08-14-2018, 07:52 PM   #205
cleoent
cleoent's Avatar
You guys using double sided tape or anything to create barrier between spoiler and paint ? Like double sided tape or foam?
Leo
2016 e-Force 2SS
Instagram @cleoent
cleoent is offline
Old 08-15-2018, 07:34 AM   #206
SilverSurfer Fifty
I placed double-sided 3M tape over the unused holes on the trunk. I’m hoping it will keep water from getting inside the trunk.
Old 08-15-2018, 08:31 AM   #207
V8Addict
V8Addict's Avatar
Drives: 2016 2SS
I used RTV Silicone Sealant around each mounting stud and when you bolt it down, it forms into a water tight plug. After it cures, it stays flexible and may prevent any rattles/squeaks.
V8Addict is offline
Old 08-15-2018, 10:38 AM   #208
SilverSurfer Fifty
I agree. Was was going to widen the left holes on their right side about 1-2mm and see if that allows the spoiler to move right enough.
C7Carbon, I suggest that you should adjust the left bolts centerline to the left about 2mm.
Old 08-15-2018, 06:50 PM   #209
cleoent
cleoent's Avatar
What about water sitting under the spoiler after a wash/rain and rusting the trunk out? is that a thing?
I like the rtv move. Does it peel off easy enough?
Leo
2016 e-Force 2SS
Instagram @cleoent
cleoent is offline
Old 08-16-2018, 08:47 AM   #210
V8Addict
V8Addict's Avatar
Drives: 2016 2SS
no harder than removing the residue from double sided tape.
V8Addict is offline
