Old 02-10-2020, 09:31 AM   #1
Josh42089
Drives: 19 Chevy Camaro LTa
Making amp rack in spare tire location
I’ve seen other people take out the foam inserts and make a wood amp rack in that location. I am planning on doing this too. Was wondering if anyone has had any problems doing it this way? Mainly lack of airflow or amp heating up too much in the summer time. I am planning on mounting a Pioneer GM-D8701.
Josh42089 is offline   Reply With Quote
Old 02-11-2020, 10:37 AM   #2
ctrlz
That amp looks like one where the lid is the heatsink. there aren't too many warnings in the manual, so I bet the risk of overheating is low. it doesn't even tell you not to mount it sideways or upside down.
if summer heat is a concern you can always wire in some hard drive cooling vans to push air across the vents.
Old 02-11-2020, 02:58 PM   #3
tecboy
tecboy's Avatar
I had the amp and the fuse box moved...used the entire compartment...going on 3+ years...never had an issue with heat
https://www.camaro6.com/forums/showthread.php?t=497975
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
tecboy is offline   Reply With Quote
Old 02-11-2020, 03:14 PM   #4
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
Drives: 2019 /2SS LT1
Do you have pics of where you move the fuse box and the factory out?
2019/LT1 2SS
RLNTLSS is offline   Reply With Quote
Old 02-11-2020, 04:38 PM   #5
tecboy
tecboy's Avatar
Sorry i do not...amp was moved to left side behind the trim and mounted to wheel well...fuse box to the right side..to the left of the battery and mounted to wheel well
Old 02-17-2020, 03:26 PM   #6
Clearly_Canadian
Clearly_Canadian's Avatar
Drives: 2017 2SS Camaro
I relocated mine too for a nice clean slate. Amp moved right and fuse block moved left. used Riv-Nuts for securing them. Haven't had any issues.
2017 Camaro 2SS, K&N Air, Borla S-Type, Cat Delete, 1LE replicas, Hotchkis Swaybars, Eibach Springs. ALL BMR arms, end links, chassis braces and cradle lockout. Hurst shifter.
Clearly_Canadian is offline   Reply With Quote
Old 02-17-2020, 04:05 PM   #7
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
It's been a little over 2 years and it hasnt overheated yet. Hasnt even really been too hot to touch either, no matter how hard I crank it. I'm sure the load on your amp may make a bit of a difference.
Old 02-18-2020, 04:32 PM   #8
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
I really want to do this but I've got a few questions,
1. Are the factory cables for the Bose amp and the fuse box long enough I don't have to cut anything or extend anything
2. Can you still remount the fabric side panels after moving everything. Amp and fusebox
3And can it be mounted without having to make extra holes
2019/LT1 2SS
Old 02-21-2020, 12:07 PM   #9
Clearly_Canadian
1. The factory cables are long enough. in fact, the amp cables almost naturally want to fall into position here. not sure why GM put it in the middle.
2. side panels fit as per stock, no modifications necessary.
3. The Amp I am sure you can get away with Velcro strips. I went overkill. I only added two riv-nuts for the fuse block to secure the bottom. the top is free standing. more than enough in my opinion.
Old 02-23-2020, 04:43 PM   #10
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
Well ,,,i bit the bullet and tried it..the left side was a breeze..i used sheet metal screws..didnt hit anything under..but close the opposite side was a little harder..theres the fuse box and some sort of sensor..im guessing its for the rear sensor.. nothing is touching the battery . it is securely attached by zip ties..now to make templet for amp rack..im planning running 2 amps going to individual subs..
2019/LT1 2SS
Old 02-24-2020, 01:12 AM   #11
Clearly_Canadian
looks good!
Old 02-24-2020, 10:14 AM   #12
puppykat33
puppykat33's Avatar
Drives: Black 2019 ZL1 M6,
does your floor liner sag with weight on it due to the foam thingy not being there to support the middle?
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
puppykat33 is offline   Reply With Quote
Old 02-24-2020, 01:24 PM   #13
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
looks good!
I'm planning on installing two amps do I need to do 100 ANL fuse per amp since that's what they call for and then do a 200anl fuse from the battery to the distribution I'm having a hard time finding information on this also the guy that posted asking about the second bottom I was just going to get like a support beam that goes across it that's a solid piece of aluminum or something really light and what did you use for the base on your wooden amp holder cuz I want to make one that fits the whole bottom inside it looks pretty sharp though
2019/LT1 2SS
Old 02-24-2020, 01:25 PM   #14
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
I'm planning on running zero gauge from the battery to a distributor and then four gauge to both amps fused on the zero gauge and on the 4 gauge also running a distributor block minus fuses from the ground which would be a zero to two smaller 4 gauge wires that would be the grounds for the amps Will the LC i2 remote start both amps
2019/LT1 2SS
