09-27-2022, 05:05 PM | #1 |
Drives: 2019 Satin Steel Metallic ZL1 Join Date: Jun 2014
Memory seat instructions
I have a 2019 ZL1, and took it in to get my snow tires put on (yes, I drive it in winter). When I got it back, my seats were not programmed anymore. I did not program them in the 1st place, I had someone do it for me. I have looked on YouTube, and the internet, and it is very confusing, and I have tried, and it has not worked. If ANYONE can save me a trip to the dealer it would be greatly appreciated. Here is what I need done.
#I want to use Key Fob 2 (Key Fob 1 is showing some wear) #2 I want to program the memory seats Can someone make it simple for me that I can just print off and try to do it myself? Thanks again! |
09-27-2022, 06:00 PM | #2 |
Drives: 2018 Chevrolet Camaro 2LT Join Date: Mar 2019
Move the seat/mirrors to the desired driving position. press set, car will beep once. Hold down #2. after a few seconds car will beep twice.
For exit position move seat to desired exit position, press set. car will beep once. Hold down the exit (car) button for a few seconds, car will beep twice. If it doesn't automatically move the seat to the correct position when you start it or when you open the door you have to go in to the settings menu in the infotainment screen. I think it's called something like memory recall and easy exit recall in the comfort and convenience menu. |
09-27-2022, 06:11 PM | #3 |
The Nights Watch
IceGoaliePaul has given you the correct instructions and tips for if it doesn't work.
Ordered 22 ZL1 Vert M6 Wild Cherry
2000 19 Jul 2021 3000 21 Jul 2021 TPW 8/23 24 Jul 2021 3400 30 Jul 2021 3800 26 Aug 2021 4000 1 Sep 2021 6000 14 Sep 2021 57 Days from accepted order to delivery. 19 Days from build to delivery. |
09-28-2022, 07:49 AM | #4 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Just duplicate the process with the secondary keyfob
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
09-28-2022, 09:02 AM | #5 |
Drives: '16 2SS M6 Join Date: Aug 2019
You can also just swap the electronic from fob 1 to fob 2 if you want to make it look new again. It's as easy as changing the battery.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB '16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20) '14 Fusion Titanium 2.0T '83 Jeep Wagoneer |
09-28-2022, 02:50 PM | #6 |
lol, absolutely can do this, I did it with mine completely forgot, was to lazy to recalibrate the fob for seating position.
