09-28-2022, 06:28 PM | #85 | |
Drives: 2019 ZL1 Join Date: Mar 2019
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
09-28-2022, 07:49 PM | #86 |
Drives: 21 ZL1 Join Date: Feb 2022
It’s all there in the log.
09-28-2022, 09:30 PM | #87 |
So the kpa on the low side is about 42 psi. Your at about 15 psi of boost at 204 kpa, did I miss your actual AFR, not sure why its commanding 11.57 which is pretty rich. What size pulley are your running? It comes with a 90 mm right? Or something close to that. I agree with 1973, low side should still be pushing enough fuel on a stock Lt4 fuel system.
09-28-2022, 10:17 PM | #88 | |
As for the low side, he was commanding 76psi but it was hitting 65psi at redline. Boost is about 16 peak at 6800. He said it wasnt out of the realm of possibility to be dropping low side. Its enough for the high side still, but who knows on a long pull like at the track vs a 5 second dyno run. The JMS was recommended by Ted to add, and that will solve the low side drop. And from what Im reading its not that bad either. Guys are seeing much more drop and still out there running them hard. But this is cheap safety for this very expensive car. Heres a better look at the log in PSI. |
09-28-2022, 11:05 PM | #89 |
your wideband didn't log. Equivalence cmd or afr cmd isn't actual, that is what the ECU is targeting. You have to have the actual lambda reading to see if actual AFR is on target with what is being commanded.
2016 NFG 1SS A8
09-28-2022, 11:26 PM | #90 | |
And I was using my laptop with my MPVI2+ because I had Ted's PID file and layout for vcm scanner. He did not want to share that with the shop doing the dyno runs, so I did it all. I dont have the proset features on my MPVI2+, so we had to log lambda (which we did) via the dyno, so it would show up on the dyno graphs. I would then send Ted's logs to him in the format he likes to read, along with the dyno graph showing lambda. So we had it all covered. The car is properly tuned, showing .82 basically across the entire range. Its like .81ish in the middle around 4k, but thats not hurting anything. So yeah we had it covered. |
09-29-2022, 12:09 AM | #91 |
Petro-sexual
I don't know... I know our combination has a bigger inlet side, commanding .84, a hit from about 55, in 4th, through the end of 4th, around 105, in cooler temps, my low side starts dipping below about 60-psi. My IPW is around 5.5-5.8. High-side creeps down to around 2600.
Just saying he might be close is all.
09-29-2022, 08:47 AM | #92 | |
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA Last edited by KingLT1; 09-29-2022 at 10:24 AM. |
09-29-2022, 10:38 AM | #93 |
Petro-sexual
That's what I have and don't have a complaint. I should have connected it CANBUS, but I didn't understand it that well at the time, and I only had the MPVI. Even with the 2+, it should be perfectly fine. I think you have to get the ProLink, though, if you don't use the CANBUS feature, and that's extra $$$.
09-29-2022, 11:03 AM | #94 |
I just have one that's hard wired and comes on when the engine is on that I connect my wire to the Mpvi2 dongle. No gauge, you can't look at the gauge anyway so I just see it on my log after I'm done. .
09-29-2022, 11:29 AM | #95 |
Ill get a WB installed eventually. I dont need one now since its tuned, so I will hold off until the next round of mods. I just want to get that JMS installed so I can rip on this without the lowside pressure dipping.
09-29-2022, 11:40 AM | #96 |
Petro-sexual
I'm not sure if it's for the same reason I don't look at my gauge either, but usually I'm too busy keeping the car straight and I'm focused on the road that I'm not looking at the WB, lol.
09-29-2022, 02:12 PM | #97 | |
You may want to re-consider the JMS though if you have any plans for any future mods or ethanol, just sayin. Been there, done that
09-29-2022, 03:07 PM | #98 |
Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
^^^^^Oh yeah. What he says.
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 |
