09-01-2022, 08:05 AM | #1 |
Drives: 1SS 1LE Join Date: Mar 2018
Alignment - 18 SS 1LE
Just got an alignment done, car feels good. I felt it might have been a smidge direct before however my wheel was never set correctly it was off a tiny bit to the right on my last alignment.
Are these new specs too conservative and that’s where my “feeling” has gone? I’ll post specs from my prior alignment labeled “ZL1 1LE”. I know we are FE4 but now the new specs they labeled under “RPO FE2”.
What this car really needs is a notification eliminator. There's a wi-fi notification. Bluetooth notification. Parking brake disabled notification. Always some annoying notification popping up. - Navigator post
09-05-2022, 01:43 PM | #2 | |
Toe changes everything about car feel.
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
09-05-2022, 02:42 PM | #3 |
Drives: 2020 SS 1LE Join Date: Aug 2020
Not trying to sound like a jerk but I don't like these readings. Too much variation between left and right in camber and toe.
I wouldn't go there again. I think .1 or .2 variation left to right is understandable but your rear camber is .8 on one side and 1.4 on the other (exceeding the front camber). Again, I don't like it. |
09-05-2022, 02:48 PM | #4 |
Here's the performance alignment settings. Note the variation between left and right is +/- .15 degrees. Your alignment is outside acceptable l/f variation.
