07-15-2022, 10:12 AM | #15 | |
In case you can't find heatsink compound locally (RadioShack used to have it, but try to find a RadioShack anymore!): https://www.amazon.com/StarTech-com-...ps%2C62&sr=8-1 |
09-30-2022, 08:48 AM | #16 |
I haven't posted on this in a while. I opened the amp up and took some pictures. It definitely looks like its been under water, but nothing stood out to me as an obvious short. I cleaned it up with alcohol and re-installed it, but still no sound. Does anyone know how I could go about troubleshooting if the amplifier is actually toast?
I have some aftermarket amps that i would rather install over replacing this thing, but someone told me most of the aftermarket digital converters require the factory amp to still work. not sure if that is true. |
09-30-2022, 09:09 AM | #17 |
Drives: 2023 2SS Convertible Join Date: May 2009
What does the backside look like?
-Geoff
09-30-2022, 10:43 AM | #18 | |
09-30-2022, 11:13 AM | #19 |
No biggie. It looks like some corrosion on the right side and near the top in the first pic.
-Geoff
09-30-2022, 01:44 PM | #20 |
Electrical Engineer
The IC601 is the STK amplifier chip and it has a lot of corrosion at the pins. There are a lot of reasons why this would not produce sound, and testing is required to determine why. Always start with the basics, does the amp chip have power? To test this is difficult as it requires you basically have it plugged in then you meter the pins.
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
10-02-2022, 12:04 PM | #21 | |
If you were confident the conformal coating protected the rest of the board, you could try removing and replacing that amp chip. It might even work with just some resoldering. These chips are only like $15-20, and this one is probably still in production. Be nice to know the part #. |
10-03-2022, 07:15 AM | #22 | |
Electrical Engineer
10-03-2022, 10:57 AM | #23 |
Looks like it contacts the case for heatsink where the grease is visible. That cage that wraps around it is either physical protection or additional heatsink. Pain to desolder and there are probably tabs that were bent before it was soldered. Harbor Freight sells a 40W iron for like $3.99 which gets too hot for a lot of things. But get some braid and that iron and I think it is doable. I always keep one of those HF cheapies around for "special occasions."
10-03-2022, 01:05 PM | #24 |
My honest opinion is to not waste your time trying to fix this - it's toast. Just move on and get a new one. There is no guarantee that replacing that one chip is going to make it work again - even if you can identify and get the chip you need. It's nearly impossible without a schematic, and as far as I know GM doesn't release one.
You can get the amp new, but I wouldn't hesitate to get a replacement from a junkyard - just make sure the donor car has the same options as yours so it is compatible. You might still have to get it flashed, though. Maybe someone on the tech side can answer that question. -Geoff
10-04-2022, 08:39 AM | #25 | |
The other thing is you need to find a dealer willing to add your "junkyard" amp. They may not be so willing to do this since it is not a new part. I don't doubt a new amp with dealer install is in the $1000 range. Just looking around ebay, there are a few listed. You will need your exact part number to make sure you buy the right one. Then you might need the donor VIN so it can be unlocked by a dealer: https://www.ebay.com/itm/16558586100...Bk9SR8qnpcD0YA Last edited by ctrlz; 10-04-2022 at 12:26 PM. |
