05-28-2022, 06:58 PM | #1 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
Black Trim Around Windows
Hey guys, what do you recommend for conditioning the black trim around the driver and passenger windows? I've noticed that I have some area of oxidation? (what it looks like) on that black trim and what to put something on it to address it.
05-28-2022, 08:43 PM | #2 |
Drives: 2018 2ss m6 Join Date: Aug 2021
I’ll second your question,,,same here
05-28-2022, 11:39 PM | #3 |
I use the "Nextzett Gummi Pflege Stift" with my rubber trimmings, it helps preserve them very well. Once already oxidated, Adam's VRT helps temporarily, it's going to be a repeated maintenance affair.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 05-28-2022 at 11:56 PM. |
05-29-2022, 08:02 AM | #4 |
You can try some optimum hyper spray polish.
It is safe for plastics and trim and used to clean them. I only use optimum polishes for that reason. I don’t have to tape any trim work so I don’t get it on there and stain it like most other polishes will do. After that maintain it with the gummi stift |
05-29-2022, 03:54 PM | #5 |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
05-29-2022, 06:04 PM | #6 | |
I've been watching a LOT of YouTube on reviews and long time reviews of a lot of these "back to black" type products. It seems most of them are not really worth it, and a couple (that are dye type products) seem better but still after 4-6 months still don't last. If I can get them replaced for a couple hundred bucks I'll just replace them and be done with it. Will call the dealer next week and ask. |
05-29-2022, 07:24 PM | #7 |
if you want a trim restore that will last.
I use Solution Finish. It is a dye that will restore and keep it black for about a year before being reapplied. Just use gloves as it will dye your hands and follow the directions correctly. big bottle https://www.autoality.com/store/pc/S...z-343p7036.htm 1oz this would probably be enough https://www.autoality.com/store/pc/S...z-343p7037.htm |
05-29-2022, 07:45 PM | #8 | |
If that works... awesome, if not it's cheap enough I won't care and I can just still then replace them. |
05-29-2022, 08:56 PM | #9 |
Both. I know they're not the same material as the weatherstripping, but this seems to work, no whitish spots so far.
05-30-2022, 11:24 AM | #10 |
Great, I'll give it a shot as these were already in decline on my 2016 when I got it in late 2017. How often do you apply the Stift to those exterior pieces?
05-30-2022, 10:43 PM | #11 |
Twice a year, because the plan is four times, once every season, but I'm so forgetful...
