06-22-2022, 12:06 PM | #1 |
Drives: 2022 Camaro LT1 Join Date: Oct 2021
Elite Engineering E2 Catch Can Install
I thought I would share my install of an Elite Engineering E2 catch can on my 2022 LT1. There isn't much for installation instructions for this, so I wanted to give my interpretation for those out there that are a little confused. I decided to go with the the E2 dual port can with the check valves. This was part number E2110B-LFX-XHRH-DC-2CV. I decided not to go with the clean side separator, supposedly the factory set up is good. It arrived with a bracket, hose, elbow, two nice check valves and enough black spring clips to complete the job. I also ordered two of the GM quick disconnects (QDF -STRAIGHT) to make the job easier. I found a number 4 rubber stopper fit my sound tube hole very well, I drilled a hole in the stopper, and fitted the elbow into it. I went a little different route and put the barb end into the stopper since it was longer and used a metal zip tie to secure it in the air bridge (intake elbow). I installed the hose to the threaded end and used a spring hose clamp on it. Seems very secure. I installed the quick disconnects on the engine side with the check valves in the appropriate locations/directions. I used the sound tube bracket that was just hanging out to route all of the hoses through. I installed the catch can to the bracket attached to the driver side suspension mount, with the included lock washer. Installed all the hoses and there it is.
Heath
2022 Camaro LT1 - Manual - Wild Cherry Tintcoat Medium Ash Gray Interior Black Metallic Rally Stripes Ordered 11/5/21 Built 4/12/2022 Delivered 5/21/2022 |
06-22-2022, 12:19 PM | #2 |
06-22-2022, 12:19 PM | #3 |
06-22-2022, 12:20 PM | #4 |
06-22-2022, 12:22 PM | #5 |
