05-31-2022, 10:02 AM | #15 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
As long as you do autocross the tune is fine. But only for slow tight turns and Nannie’s off. Stock tune locks and unlocks differential later for roadcourses. Autocross needs that done sooner.
05-31-2022, 12:18 PM | #16 |
Yes. Just replying to the post that the autocross tune was designed for tight autocross situations in Nannie’s off. Op can turn Nannie’s off but if on the street I won’t suggest that for safety’s sake. And of course, EDiff will do its thing to an extent even with Nannie’s off, just a lot less. Though I never notice that at autocross.
05-31-2022, 12:23 PM | #17 | |
Drives: 2017 1SS 1LE Join Date: Oct 2015
05-31-2022, 12:46 PM | #18 | |
Nannies off in autocross ( I don’t roadcourse) is a bit more nimble then track race. Mostly in corner exit and rotational feel But that maybe irrelevant if you are just talking about street use. Biggest issue on course Nannie’s off is slow corner exit snap oversteer. It’s a EDiff issue if not on a wide sweeping turn. |
05-31-2022, 12:52 PM | #19 | |
I can definitely use the power on the street maybe YOU cant so much so that this car feels very overbuilt fir the stock hp and torque which isn't necessarily a bad thing. I've noticed both on street and track being in race mode makes power on corner exits at speed alot more effective. Definitely the edif working it's magic. |
05-31-2022, 01:10 PM | #20 | |
Yeah track race is good. It only interferes with me on course when I screw up come into a corner to fast and exit is f’ d up. Then it kills the power and hits the brakes. Very annoying..lol |
05-31-2022, 01:16 PM | #21 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
The eDiff AutoX tune is only active in track with all nannies off. This is NOT for driving on the street, and it's really not for a stock car either. When the car is stock the eDiff AX tune is too aggressive and will cause more oversteer. Fun, but not exactly safe or fast. Maybe better than stock but there are tradeoffs. If you get an ideal alignment (requires camber plates and rear toe links) and a stiffer front bar + AX tires then the tune makes sense.
I'd also encourage folks to NEVER drive on the street with all nannies off. It's really stupid imo, and unless you have a ton of experience driving high-hp rwd cars and Randy Pobst like skills you'll eventually crash the car. The car seems tame and forgiving but switch to track and turn all the nannies off and it's not the same car. Well worth paying to run in an autox or track event to experience this, but please be careful on the street.
05-31-2022, 01:28 PM | #22 | |
05-31-2022, 01:31 PM | #23 | |
This is my 3rd camaro (none wrecked), second 1le and the least power of the 3 with the most intrusive electronics. Driving without nannies on the street isn't dangerous, HOW you drive without nannies on the street would be the deciding factor. Professional randy pobst skills not necessary with this car its probably less of a race car than a base model c7. If you feel like this car is dangerous or driving it without nannies is "stupid" and guaranteed to get you in a wreck maybe this isn't the right car for you.no offense intended even though you feel the need to throw around insults at strangers but I find that telling of the kind of driver you may be. |
05-31-2022, 04:10 PM | #24 | |
Honestly, if you're driving an SS 1LE on the street to the point electronics are interfering I hope you get your car impounded before you kill yourself or someone else. Look up sociopath, because that's you!
05-31-2022, 05:15 PM | #25 | |
05-31-2022, 05:39 PM | #26 |
Could be, but I never use the nannies when I'm driving fast so I have no idea what you're talking about.
05-31-2022, 05:48 PM | #27 |
05-31-2022, 05:53 PM | #28 |
If I do it'll most likely be into a concrete barrier though, it would suck but I can live with that.
