02-13-2022, 03:46 PM | #1 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Is this step in the oil change procedure really necessary?
Now be honest- how many of you have changed your oil without "pre-heating" it?
It no longer seems really necessary to me due to the low (0w/40 full synthetic and the 0w is when it's cold) oils we use today. I mean didn't it all drop into the pan after the last full drive that actually got the stuff good and hot? I don't mean middle of winter with freezing temps but when the ambient temp is >60 degrees or more it still comes out briskly. If it's hot-hot it flies outta there like a living creature trying to escape! I've hit the inside sidewall of the front passenger tire. Some may say the start-up will stir up settled stuff lying in the pan, but I think even when "cold" the flow of 10 quarts would be sufficient to move out any particulate bits the engine has spit off. I mean, I hope I don't have the Titanic in the bottom of my motor but I think I would have known before the oil change if I did. Not looking to stir up controversy or commit heresy against automotive common wisdom- just finished changing the oil and wanted to get some opinions. Thanks- |
02-13-2022, 04:31 PM | #2 |
Drives: 2016 Camaro 2SS Join Date: Jun 2016
I always warm it up a little. It's not hard to do - why not?
02-13-2022, 06:11 PM | #3 |
Drives: 2023 ZL1 Convertible Join Date: Jan 2009
You will get so many answers for this. I have tried both methods....I prep the car the night before, put it up on ramps etc, let it all drain down to the bottom hoping you will get every last drop out. Some times I will let the engine idle for a few mins to warm it up. I think it's really up to you.
Jason
2022 Equinox RS
2023 Trailblazer RS 2023 ZL1 Convertible |
02-13-2022, 09:18 PM | #4 |
Who Needs to KNOW?
I run it for few minutes - just so it flows out faster. 10qts of thick, cold oil will drain veryy slowly.
Optional - but a good idea. Some might even pour some fresh oil in to help flush out the old.
ing for grip.
02-14-2022, 05:27 AM | #5 |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
I cannot see how it would matter one way or the other if you warm up the oil or not.
Running the car for a few minutes to get the oil warm is not a bad idea but it can suck doing an oil change with the temp at operating temp. Do what works best for you. |
02-14-2022, 05:44 AM | #6 |
Drives: 2016 2SS Convertible Join Date: May 2012
If you want to have the oil analyzed by Blackstone or another lab then it matters for the accuracy of the test. Blackstone recommends that you bring the engine up to operating temperature to remove excess moisture and fuel from the oil and then let it cool enough to be safe.
02-14-2022, 09:19 AM | #7 |
I drive it around the block once. That does get it warm.
I don't like getting burned by oil or messing with a hot filter. I do let the oil drain for about 10 minutes, until it is actually coming out in drops and not a thin stream. |
02-14-2022, 11:12 AM | #8 | |
Nobody wants to crawl under a hot engine, so unless I got some free time (or the inclination), after a drive (never seems to happen)- I'm changing mine at room temp. Here in S. Utah we are in the corner of the Mojave desert and it stays pretty warm in my attached garage. Also my method of draining is to just jack up the front driver's side corner (and stick in a jack stand) which tips the engine back toward the drain and puts the drain on the downhill side. I'm confident I'm getting all the old stuff out and I give it lots of time to drain. There you have it. Thanks for the honest responses and have a great week! |
02-14-2022, 10:54 PM | #9 |
SHRFT
Drives: 2017 2SS vert 50 anniversary Join Date: Dec 2018
The main reason I warm the engine before an oil change is to suspend any contaminates in the oil. They should then flow out much more efficiently. As VENTMASTER stated, I also raise the driver side for a quick flow speed.
Even though all the mosquitoes are roasting in HELL, I still don't like winter.
02-15-2022, 07:50 AM | #10 | |
Thank you Al Oppenheiser!
and FYI: 0w40 is higher viscosity than 5w30. |
03-29-2022, 02:36 PM | #11 |
Drives: 2021 Camaro 1SS 1LE 10AT Join Date: Jul 2021
I send my oil in to Blackstone every time and I like to pre-heat it so that the sample is well mixed.
2021 Camaro 1SS 1LE 10AT (Track)
2019 VW Golf R DSG (Daily/AutoX)
