06-04-2023, 11:58 AM | #15 | |
Hot Camaro
06-04-2023, 12:11 PM | #16 | |
It definitely isn't normal for the rear end to continously wag or feel unstable, so the alignment is 100% worth having. If it still doesn't tighten up the rear enough for OP, then I agree the next thing is extreme performance summer tires, then the BMR suspension parts cannon (for the record, I only have their rear cradle lockout kit and it's enough for 735 rwhp and Michelin PS4S here, once the tires hook, the rear is rock stable).
06-04-2023, 12:27 PM | #17 | |
Hot Camaro
I agree, though... lots of variables that could come in to play so it's bit of a "shotgun blast" approach of things to look at. |
06-04-2023, 01:44 PM | #18 |
Drives: 2020 Camaro SS 1LE Join Date: Aug 2020
Rear sub frame bushings. Either do the BMR inserts or go to a solid bushing.
06-04-2023, 03:48 PM | #19 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
06-04-2023, 08:09 PM | #20 |
Well it’s not tires and multiple alignments
06-04-2023, 08:18 PM | #21 |
Drives: Chevy Camaro ZL1 Join Date: Feb 2023
Still beating this rotted dead horse I see.
06-05-2023, 10:01 AM | #22 | |
Drives: 2017 1SS 6spd Join Date: Jan 2011
07-01-2023, 12:14 PM | #23 | |
Here are many others with this same issue... https://www.camaro6.com/forums/showthread.php?t=500793 |
07-01-2023, 07:23 PM | #24 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
Meh. Seems normal to me. Mine broke loose very easily on the stock Goodyears, especially when I had to accellerate from a dig to jump into traffic.
07-01-2023, 08:08 PM | #25 |
Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
My ZlE was real wormy when I first got it. Took it in for an alignment and it wouldnt align to spec on the rear. Bought all the BMR stuff and it was like a different car. Now, even if it does break the tires loose, it doesnt feel like the back end is going to come around
07-02-2023, 07:31 AM | #26 |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
I’ve experienced that kind of wiggle, but only under WOT while doing a hard lane change, also on Continentals, not in a straight line WOT. I chalk it up to the tires and me being a little too abrupt straightening out in the new lane. Increases the pucker factor a bit when you’re at triple digit speeds.
07-02-2023, 01:26 PM | #27 | |
07-02-2023, 02:49 PM | #28 |
Lol. I don’t know about that. I suspect you’re a better driver than I am.
