Old 05-25-2023, 09:31 PM   #1
Green82
Drives: 2022 camaro lt1
best tuning device
looking at some tuners for the camaro and i have found HP tuners (MVP13)
and DiabloSport. out of these 2 which is the best option?
do they have preset tunes where you can change things when you install a new part or does it all have to be done from a professional?
Green82 is offline   Reply With Quote
Old 05-25-2023, 09:40 PM   #2
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
For these cars virtually all the best tuners use HP Tuners. No preset tunes but almost every experienced tuner will have a base tune that they can load in and fine tune very quickly (for bolt ons). Once you dig into cams, big fuel system changes with forced induction, etc that takes more time.
Old 05-25-2023, 10:22 PM   #3
Green82
i was wondering because i came from owning a honda and the use ktuner and Hondata but almost i all tuners used Hondata since it was better
would i need a experienced tuner to remove the speed limiter and turn off the cylinder shut off?
Old 05-26-2023, 07:16 AM   #4
adamjwilson
Drives: 2022 Camaro 2SS A10
HPTuners (MVPI3)
MPVI2 (only works on older versions of software) but most tuners have this version as well as it has many options that the new version does not unfortunately. (EPA)
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods
adamjwilson is offline   Reply With Quote
Old 05-26-2023, 07:30 AM   #5
Joshinator99
That’s not hard to do. Hit up KingLT1 on this board and he can hook you up with a starter tune (plus he can help you tune for mods as well).
