05-22-2023, 09:20 AM | #43 |
Drives: 2021 1SS 1LE Join Date: Nov 2020
Go it...I might try the XR2s at some point up front.
Follow my build - https://www.camaro6.com/forums/showthread.php?t=594295
05-22-2023, 01:15 PM | #44 |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
I went to 60s all around and will use them next after my 70s are done, hopefully that will help a bit when it comes to ice mode
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
06-20-2023, 01:06 PM | #45 | |
Drives: 22 ZL1 1LE A10 Join Date: Feb 2022
07-17-2023, 04:00 PM | #46 |
Drives: 17 hyper blue 2SS M6 Join Date: Mar 2018
I know there's a fair amount of people here who will just be appalled with my question here, but I'm going to ask anyway.
With regards to ice mode, I'm wondering if anyone has tried just pulling the ABS fuses? Disable the whole system and just manage your brakes like the old days. I may give this a try at my next track day, challenge myself with threshold braking. I already run with everything else off. |
07-17-2023, 04:07 PM | #47 |
Drives: Camaro SS 1LE Join Date: Jun 2021
Suspect that wouldn't work as expected. In my C5Z when I had an ABS computer failure the system defaulted to dramatically increasing the rear bias, obviously it made the car very unstable and brake zones lengthened as a result.
07-17-2023, 04:11 PM | #48 | |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
From experience, turning all nannies off won't affect hard pedal/ice mode due to yaw. @Baddawg53, I'd guess disabling ABS entirely isn't possible without causing other issues, not sure I've heard of anyone trying it though.
07-17-2023, 06:34 PM | #49 | |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
I have ridden as a passenger in a Miata on track with flat spotted tires and it is not a pleasant experience! |
07-17-2023, 09:41 PM | #50 | |
I do think the risk of flat spotting the tires is the biggest risk factor. I'm thinking if I try this, much like when I first turned the nannies off, I'll have to dial it back a little and really pay attention to the braking. Ultimately I'd like to have the confidence that when I need the brakes to be there they will. I have a new(used) ebcm being delivered tomorrow, I don't think I'll have time to install it though before Friday at Laguna. |
07-18-2023, 12:56 AM | #51 | |
I’m interested to hear more about your thoughts on this though… I can’t recall if I had every single thing turned off both times or not to be honest, but I’m very sure in the video where it happens at slower speed, that I did have everything turned off. What would the other affects of disconnecting are killing the YAW sensor be?
07-18-2023, 01:01 AM | #52 | |
07-18-2023, 03:38 PM | #53 | |
This is from experience I take it?
07-18-2023, 07:36 PM | #54 |
Yep, otherwise it just stays a locked pedal.
07-18-2023, 11:33 PM | #55 |
Good to know, I never pumped the brake, but the brakes eventually started to slow the car down again at a fast rate on their own, but obviously I’d like to avoid waiting for the computer to figure it out on its own..
07-20-2023, 03:18 PM | #56 |
Just realized I (and others in my situation) have one more option to get rid of Ice Mode... I have an updated 2019 ZL1 EMCB ABS Brake Module but not one from a ZL1 1LE (because I haven't been able to find one yet) so I'll keep looking...
