05-14-2023, 04:14 PM | #1 |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
Engine Braking Deceleration Delay
Intermittently my car will almost act like cruise control is still on for about 3 to 5 seconds after downshifting before the car starts to slow down, essentially the car will start to slow down more than it just was immediately after downshifting even though the engine is at a lower rpm than it just was immediately after the down shift took place. It’s very intermittent.
The boost bypass valve was suggested as a possible culprit and indeed it was disconnected and not working but after repairing it the issue is still there Any thoughts?
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
05-16-2023, 03:08 PM | #2 |
Drives: V8 Camaro LT1 Join Date: May 2023
I bet the problem is Throttle Position Sensor - The TPS tells the ECM how much you're pressing the gas pedal. If it's faulty, it might send wrong signals and cause a delay in throttle response after downshifting. And this could make your car maintain speed for a few seconds before slowing down.
