04-22-2023, 04:15 PM | #1 |
Drives: audi s3 2008 bmw 135 2010 Join Date: Mar 2020
pe tables alcohol advice
with flex sensor gas and alcohol pe tables must match
thanks |
04-22-2023, 04:19 PM | #2 |
They do not have to match.
04-22-2023, 04:49 PM | #3 |
my alcohol table is lower that is correct
example 5120rpm -1223 throttle 5120rpm -1160 alcohol should i upload them? either thanks |
04-22-2023, 05:11 PM | #4 |
I don’t have my laptop handy so can’t check, but it’s not unusual to see the alcohol run a bit leaner than 93. But that looks like more of a difference than I would be comfortable with. I don’t know anything about your combo but would target .82 lambda in a stock bottom end LT1 with a blower and .84 with a forged bottom end.
04-22-2023, 05:47 PM | #5 |
afr log and correction
if it does not maintain the indicated value thanks !!!!! in oct 93 I am in lambda .817 |
