04-03-2023, 03:16 PM | #1 |
Drives: 2023 ZL1 A10 Join Date: Nov 2021
A Day at the Strip
Hi All , took the Z out 1st time with her. I had my 22 1SS last year in the Series.
Summit ET Racing Series at Wildhorse Pass MS Park in Chandler Arizona. Try to keep it short . 1st time trial pass , everything off in Track mode (race) 22 or 25 tire pressure, spun bad blipped throttle ran ran 12.72 @ 122 So I figured turn on Stab track Trac Control, tour mode 19 tire pressure, 10am 65 deg. 11.45 @ 123 mph ,( same settings all day.) 2nd ttp 12:45 pm 78 deg. 11.59 @ 122.9 RT .007 Time to Dial in (11.60) 2:41pm 82 deg. Ran a 11.66 @ 121.6 perfect lite 2nd round Dial 11.68 4:32pm 84 deg. (had to run my buddy Pat dang we tried to stay apart) I dang Big Red -.023 soon as I seen red I back out ,then I hit it again, shouldn't of at that point . 11.70 @ 120.3 . Prior to last year w SS , I haven't been down the strip in 21 years, I was nervous kinda overwhelmed, but rekindled fun I need to figure out how much I will be going out , and they may close the Track (still up in the air) .If they do ,then it's Tucson Raceway, 2. 1/2 hr drive each way and that's too far to drive on the Drag Pak , then I need a trailer and truck . Next Question what rear wheel size (17") and what bs and offset. MT Drag Radial 305x 45-17 Thanks guys
2023 ZL1 A10 Shadow Gray Metallic
04-03-2023, 03:39 PM | #2 |
Many here including me use the VMS 17x10 5x120 REAR V STAR WHEEL
04-19-2023, 09:07 PM | #3 | |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
04-20-2023, 07:45 AM | #4 |
Drives: 98 Camaro Join Date: Apr 2022
Car looks great. You guys aren’t blessed with the good air like we have on the east coast but looks like you had a lot of fun!
04-22-2023, 07:50 PM | #5 |
Hi all, had a good day at the Drags, Wildhorse Pass MS Park, Summit ET Racing Series race 6, I just can't get a handle on the E throttle, such a delay, I'm way late so I roll in a tad bit deeper and RL by a bunch. Did make it to the 3rd tho ,
Car is consistent 11.55 @ 124.4 tires @ 20 psi, TC & Stabil Control on Tr mode. Is there something I'm missing, like my brain My 68 Camaro ran 11.0 and could cut .030 under lites consistently. Any suggestions. Thanks
04-23-2023, 07:27 AM | #6 | |
https://cdn10.bigcommerce.com/s-o39d...0.1280.jpg?c=2
04-23-2023, 07:57 AM | #7 |
If you do skinnies, the et street front matches the 305 R perfectly
They are light for a radial, at 18lbs
04-23-2023, 01:56 PM | #8 |
Drives: 2022 2LT RS Convertible Join Date: Apr 2021
Hey JTS, Must have missed you. I ran Wildhorse and Tucson. In Feb. and March just before the big guys showed up at Wildhorse. I guess next year when I'm down there I'll spend most of the time at Tucson drags. If you're out and see a S-10 John Deere green and yellow, that's my brother-in-law. Enjoy the sun up here we're to start racing April 29-30 at Byron Il. If it doesn't snow or rain.
04-23-2023, 03:53 PM | #9 | |
Small world, your Bro in law was there yesterday, the Deere colors stand out. If they do close Wildhorse, Tucson Raceway is a 2. 1/2 hr drive one way 165 miles, don't think I'm gonna commit to that. I was thinking buying a trailer , but have to get a truck as well then I'm around 50k and add a Drag Pack at 5 k. Just don't know if it's gonna transpire. Race # 7 &8 May 20 , June 17 are nite races, then the season is over too hot. Enjoy your season of Drags.
04-24-2023, 07:06 AM | #10 | |
04-24-2023, 05:22 PM | #11 | |
Thanks laynol , I know I was on the high side for a Drag Pak, but if the local track closes, 5 hours round trip to Tucson Raceway I can't justify driving . And as stated above used truck and trailer 50k that as well can't justify.
04-24-2023, 06:25 PM | #12 |
Correct, my 20' Heartland steel trailer was 4100.00, I got a really good buy since they are normally about 4800.00. Nice used truck 45,000 or even a new Chevy Sliverado Lt you can buy for that with a 5.3 or another 1000.00 a 3.0 Diesel like mine.
