04-02-2023, 12:38 PM | #1 |
Results: First test with new build
No traction with R888R
'20 ZL1 1LE A10,
04-02-2023, 01:03 PM | #2 |
Good problem!
04-02-2023, 01:26 PM | #3 |
Haha, not really, because what can he do now? Slicks? Brick under the gas pedal?
04-02-2023, 02:21 PM | #4 |
I saw a ton of MT out there which is not surprising. I didn't have any confidence these tires would work at the strip this year. Tried 16# to 25# but nothing helped.
'20 ZL1 1LE A10,
04-02-2023, 04:11 PM | #5 |
Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
Yes sir, you are past the point where multi-purpose tires are going to work for max straight line performance. At least you can take comfort in knowing you tried.
2017 ZL1 - PB 8.05 @ 172 MPH @ 3730 lbs @ 70 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
04-02-2023, 04:55 PM | #6 |
R888R is not a drag strip tire, period. Great rolling racing and high HP street car tire, but that’s it. At the drag strip, time to break out the drag pack my friend.
04-02-2023, 05:44 PM | #7 |
I've got a set of 17x10 bead locks and I dusted them off when I got back home. Someone said the MT ETS R is now hard to find. I think I need the P315/50R17
'20 ZL1 1LE A10,
04-02-2023, 08:51 PM | #8 | |
https://www.mickeythompsontires.com/...es/et-street-r
04-02-2023, 10:25 PM | #9 | |
'20 ZL1 1LE A10,
04-03-2023, 06:26 AM | #10 |
305/45 is a 28” tall tire that will fit your wheel well and should play nice with your front runner tire (need to be within 1” of each other). The 315 is a 50 aspect tire that is 29.4” tall…probably going to be a problem on both fronts.
04-03-2023, 08:30 AM | #11 |
My fronts are 26.65 in. and Mickey is 28.1. Close enough.
'20 ZL1 1LE A10,
04-03-2023, 11:12 AM | #12 |
Front and rear needs to be under 1" difference or stabilitrak freaks out. So I wouldn't do the 315/50.
Either way, not much you can do as hard as that blower is spinning to get traction. I could pull timing out of it down low but I still don't think it does enough. You might consider a smooth boost controller so you can lower boost on the hit.
2016 NFG 1SS A8
04-03-2023, 11:18 AM | #13 | |
Shoot me a tune with an adjustment on the hit. I'll do a T&T soon with Mickeys and send you the logs. Thanks. My times: 60 ft. = 1.85 (ran 1.58 last year) 1/4 = 10.35 mph = 145
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 04-03-2023 at 12:25 PM. |
04-03-2023, 01:30 PM | #14 | |
2016 NFG 1SS A8
