09-22-2022, 07:20 PM | #15 |
Drives: 2022 ZL1 Join Date: Dec 2021
Excellent Information
Great job I like it |
09-23-2022, 10:10 AM | #16 |
Petro-sexual
What gear were those run in?
09-23-2022, 10:12 AM | #17 |
Drives: 21 ZL1 Join Date: Feb 2022
09-23-2022, 10:14 AM | #18 |
Petro-sexual
Even if they don't, 6th will show just a little less, so there's still relativity in what you'd get.
09-23-2022, 10:21 AM | #19 |
Looks from their log of the maggie tune it was in 6th because I see it redline at 145mph. I thought 7th was closer to 170mph at the top of the gear??
09-23-2022, 11:18 AM | #20 |
Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
That dyno graph is Rich AF.
If I know Ted, based on past experience he'll probably lower your MAF settings in your tune based on the log to get the ECM to throw less fuel at things. As I stated earlier, there's a lot of power left on the table there. And contrary to popular belief, sure running rich may keep things cool but it's still bad for the engine as the excess gas rinses the oil residue off of the cylinder walls opening them up to potential scoring and damage. No bueno. When I worked on Motorcycle engines I could easily tell which motors were running rich based on the condition of the cylinder walls. |
09-23-2022, 11:45 AM | #21 | |
And let me tell you, comparing his last revision to the maggie tune and the stock tune, WOWOWOWIE. His tune makes the car feel so crispy already. Throttle input is like perfect. Its snappier than before x10. I can already feel a massive difference in the cars willingness to WANT to get into boost. When Im doing the part throttle logging, I have to be very careful not to get it into boost and man its hard. With the maggie tune, it was so lazy and I was honestly disappointed in the performance compared to stock. With the JRE tunes so far, things are looking up in a big way. I cant wait to get this on the dyno and see where we land. And I will try to get the operator to run the car in 7th vs 6th. That would help a bunch in power numbers compared to the last graph. So far JRE for the WIN! Its just too bad I dont have a wideband yet. I really didnt want to do that yet. |
09-23-2022, 11:55 AM | #22 | |
09-23-2022, 12:09 PM | #23 |
Mine is mounted above the driver's side a/c vent on that small vent (of unknown name) and cable runs down into the dash and taps into the accessories power lead.
'20 ZL1 1LE A10,
09-23-2022, 12:10 PM | #24 |
09-23-2022, 01:59 PM | #25 |
Petro-sexual
Yeah. That looks like 6th Gear. Dyno'ing in 7th is probably around another 20-30 WHP. That is more along the lines of what many here have posted. You're Spark could probably be played with a little, too. I'd also make sure to record MAT as that's a table that will be correcting advance based off an extrapolated intake temperature. I suspect if you could get advance to about 20-22*, you'll be close to 700 at the tire. That's will probably only be in around the mid-70*s ambient though.
You'll well on your way toward calibration and optimization. You might capture inlet pressure/vacuum, too. Changing from a ported LT5 TB to a 103 allowed for 2-3 kPa drop, too, from a set-up we have. JMO
09-23-2022, 02:16 PM | #26 | |
Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 |
09-23-2022, 02:21 PM | #27 |
Why would you tamper with Ted's tune? They do not need to be "dialed in".
09-23-2022, 02:32 PM | #28 | |
Drives: HBM ZLE Join Date: Aug 2017
