Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LFX Engine, Exhaust, and Bolt-Ons
Old 04-10-2020, 03:18 PM   #15
p.s.
Drives: 2014 v6 manual
Originally Posted by SonicChris View Post
I used the highest strength steel epoxy I could find, was only 10 bucks or so. 900psi tensile strength, heat resistant to I think 250, cleaned and degreased the manifold real good first. It isn't coming out anytime soon, trust me. Now if you used something weaker and not high temp resistant, you'd have issues
I was assuming you swapped your intake for a plastic lfx manifold? steel epoxy on plastic?
p.s. is offline   Reply With Quote
Old 04-10-2020, 05:13 PM   #16
SonicChris
SonicChris's Avatar
Drives: 2011 RS
Yup, bonded on there pretty good. Was a total bitch to sand and smooth, worked on it for hours. It ain't going anywhere
SonicChris is offline   Reply With Quote
Old 04-12-2020, 02:43 PM   #17
15RS2NV
Ponies are for girls
15RS2NV's Avatar
Drives: 2015 RS LFX Red Hot A6
Originally Posted by DSX_Camaro View Post
(Also, most people have a ton of issues with the Accel coils... you might get lucky if you try them, but the Delco ones are by no means bad)
I've had them on the car since December, no issues with daily driving or at the drag strip. I've always used MSD products.
H&R 1.8/1.7” drop, Overkill 80mm + intake ported by AFS, 1" insulator MACE, Accel Super Coils, THR cai, JET MAF sensor, Hurst shifter handle, GPP strut tower brace, CI ice cube tray hood vents (functional) @SemperFiCamaro
15RS2NV is offline   Reply With Quote
Old 04-12-2020, 11:17 PM   #18
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Yeah, most people don't, but my personal friend went through 4 defective ones trying to get a full 6, and I think another member here (IneedAZ) had a topic in 2016 about it. Other people have hit or miss encounters with them also, but it seems to only be our cars, not the brand or something.
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
DSX_Camaro is offline   Reply With Quote
lfx manifold
