Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Old 10-17-2019, 04:00 PM   #1
Vrodviddy
Drives: 2018 Camaro ss
520 at the wheel . Thanks vengeance!!
Just wanted to give shout out to mike at vengeance. Guy is an amazing tuner!! Met and exceeded what I was hoping for.
Tsp vvt3 235/239
DOD delete.
Tsp 2 inch headers
Borla exhaust
Rotofab
E85.
And a tickled pink owner at the wheel
Vrodviddy is offline   Reply With Quote
Old 10-17-2019, 09:11 PM   #2
KH6GEN1LE
Drives: 2017 Camaro 1le
Nice set up! Do you still have the LT1 fuel injectors?
KH6GEN1LE is offline   Reply With Quote
Old 10-17-2019, 09:53 PM   #3
BluinSC
Drives: BVM 1SS
How much did install run you?
BluinSC is offline   Reply With Quote
Old 10-17-2019, 10:03 PM   #4
LARRY01Z28
Drives: 2001Camaro Z28
that's awesome congrats
LARRY01Z28 is offline   Reply With Quote
Old 10-18-2019, 05:40 AM   #5
Vrodviddy
Thanks. Yes, still running stock. But come spring i will be upgrading fuel in prep for super charger.
Old 10-18-2019, 05:51 AM   #6
Vrodviddy
Well about 4kish but thats just in parts because i did everything myself. but if vengence had done it, would of been 8k easy for everything i did. Tune cost 800 total, for base tune and then custom tune for e85. Just fyi if you tune e85 your paying for two tunes because they tune for pump gas and then for e85. Got a 22 hp gain with e85. It was worth it for me, but many don't factor in the tune required. So the fuel sensor was 250$ plus 575 for tune(but again first tune so a custom pump gas tune had not been done yet, would be cheaper if this had already be done). That 825$ dollars for a 22hp gain. So keep that in mind when considering going e85.
Old 10-18-2019, 05:55 AM   #7
Vrodviddy
Thanks man. Tickled pink. Plus having the added pride that i did the build myself.
Old 10-18-2019, 08:20 AM   #8
asthmamax11
asthmamax11's Avatar
Mike is the man. He really knows these cars.
16 1SS M6 White
Magnuson
Roto Fab
Solo Performance axle back
Basic suspension upgrades
Hurst pistol grip short shifter
Throttle controller
551/541
03 Jeep Wrangler
Daily Driver
Old 10-18-2019, 08:52 AM   #9
gmcvt
gmcvt's Avatar
Drives: 2019 Camaro 1SS A10
Nice numbers. Mike is great...he tuned my 10 and is working on my 19 right now. So I assume you are an M6?
"Jesus said to them: I am the way, the truth and the life and no one comes to the Father except through me" John 14:6
2019 Camaro 1SS A10
2018 Mustang GT A10 Kooks Lt's, E85 & Lund tune*SOLD*
2010 Camaro 2SS/RS M6 Silver- CAI, Bo-body, VRSP-2 cam, Kooks 1 7/8 Lt's w/cats, Magnaflow street CB(15089), QTP ovals, Elite can, Vengeance Racing tune. *SOLD*
gmcvt is offline   Reply With Quote
Old 10-18-2019, 09:04 AM   #10
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I am surprised you didn't do drop in piston's while it was apart for the cam install if you are planning on going FI. Would of saved a lot of work down the road. You will be limited to low boost with the cam because the power is going to be into the "roll the dice" territory far as the SBE and how much power it will tolerate.
Either way good numbers and it's nice to see guys doing there own work!!
2016 NFG 1SS A8
Options-[2SS Leather/NPP]
Perf. mods-[Whipple 2.9/LT4-LPE-JMS Fueling/ LT5 TB/Rotofab Dry/Flex Fuel/CA ORP/FM NPP Axle back]
Old 10-18-2019, 09:55 AM   #11
Vrodviddy
Correct. I upgraded the trans-fluid to before hand.
Old 10-18-2019, 10:00 AM   #12
Vrodviddy
Yes, i know. I wanted to. But was on a budget. Plus honestly may be 2 years before i get the supercharger. I'm saving for it. But that will be phase 2 and probably re-bore and everything. But for now i wanted at least the agreesive sound and better throttle response. I'm considering building a spare block on the side and add as i go.
Its very rewarding know I did it and with such good numbers turn out. Thanks.
Old 10-18-2019, 11:21 AM   #13
GAOLDGUY
GAOLDGUY's Avatar
Drives: 2012 GMC Sierra, 2018 Camaro SS 1LE
Hey Vrodviddy, I live in Lawrenceville. Do you have emissions testing where you live. I need to pass a sniffer test here in Gwinnett County. What did you do about that? Also, do you mind me asking what you used for documentation on the cam swap? It seems faily complex on these LT1s.
GAOLDGUY is offline   Reply With Quote
Old 10-18-2019, 12:37 PM   #14
Vrodviddy
Oh cool your not far at all man. Well if you want some help buy the beers and i got a good wrench hand!!. lol
I am up in dawson county. we have no emissions so i am free reign up here and love it. Dawson county is racing country and home to many nascar celebrates including Bill Elliot. Its in their roots here so pretty sure i'll never have to worry about emissions.
The process isn't crazy bad, but you need to do your research before hand and attention to detail is everything. I am an automation engineer by trade so pretty mechanically incline and done alot of work on various cars in the past. so felt petty comfortable with accomplishing it. Far as documentation i used several references. I used GM manual mainly, there expensive as hell though, but there are websites where you can rent a digital copy for a few days for like 20$. I screen shot the parts i needed and put them in a file. Second reference was a very well done guide on the corvette forum by a member named Fryreant. Dude put some serious time into this guide and was huge help to fill in the gaps where the GM manual can at many times leave you scratching your head because the illustrations are unclear and sometimes even wrong. Also there is a video out that gives you an idea what it takes, but would not use as a guide cause he takes alot of short cuts that while worked for him can go badly quickly. But the guys youtube channel is "get it at will". I have respect for him doing though. Again just use as a courage tester, to see if after watching you would be comfortable. Lastly torque specs!!! So freaking important!! Have a guy im trying to help, but he may of trashed his engine due to not following proper torque specs when it came to his valve train. Then drove it like so. Good little cheat sheet i found listed below for quick reference of every bolt. I'll list all my references below.
https://www.repairprocedures.com/ser...100306584.html
https://www.corvetteforum.com/forums...all-guide.html
https://paceperformance.com/files/pd...rque-specs.pdf
Important tips from my experience.
1.
If you buy a kit from tSP or anywhere really. Just because it comes with pushrods. don't assume there the right ones!! These don't take in account if you had heads shaved or whatever else that may effect this. Always check your preload for hydraulic lifters and torque to spec.
2.
32% fuel lobe.. got to do a lash cap on fuel lifter. make sure its .060. Most kits come with .080 and are to thick. This will sheer your fuel pump bolts and send it flying.
3.
Radiator removal. God i cant stress this enough. Do it the right way and remove front fresica. See alot of people try to take it through the top, not only does this possibly damage the radiator but it actually makes it harder in the end. The condenser not required to be disconnected. used bungi cord to hang it out the way. Just fyi, 400$ to recharge your system so avoid it if you can. Found that out the hard way. lol.
4. This can be done with engine in the car. I did it this way. But it did have its challenges and in hindsight, probably would just pull the engine if i had to do it again. Takes dropping one thing and your pulling the engine anyways. lol.
5.
Can not stress this enough. If this is your daily driver.. DON'T DO IT!! My car has 9k miles on it cause its not my daily. It took me two months with my car on jacks in my spare time to get this done. ( i work alot plus have a handicap hand that really slows me down). Takes proffesionals that do this daily 12 hours to finish. If its your first time, i would triple that easily.
6. oh last tip... most important!! Make sure your garage fridge is always stocked with cold beer. You will get frustrated many times!! lol.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
