08-31-2019, 12:13 PM | #15 | |
Drives: SS 6 speed of course Join Date: Jan 2016
This is from my DMV: "Can I get a waiver for readiness? No, there are no waivers for readiness as per EPA guidelines." I'm sure GM's software tool can do anything.... but you ain't getting a hold of that are you? So sure when I was in west texas 22 years ago they did a visual of your "check engine" light (piece of black tape fixed that). and you were good to go. For the last 21 years I've been in Austin and it is plug intoODBII port check smog monitors. So please somebody do a cut and paste of HP tuner or whatever and show me the box that says Set all smog monitors to ready... and I'll be sure to file a report with the EPA on Tuesday.... I lived in CA for a year, and they, of course, sniffer check, visually check, and look for CARB exemptions. Heck, they even have road side checkers, probably crawrl in your bedroom at night to make sure you are doing everything copasetic. I've heard Houston has gone to sniffer. It will be only a matter of time before Austin goes to sniffer cause all the people from CA moved here (after destroying their own state). Can't have any Texas get out of safetycheck in 10 minutes and 18 bucks, nope goonna do a tread mill sniffer and that is by appointment next month tuesday for $200, better hope you don't fail or the brown shirts come in to ask questions...
08-31-2019, 12:33 PM | #16 | |
08-31-2019, 01:45 PM | #17 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Oldman as usual your posts have left me scratching my head. Are you for this mod in Ohio or against it?
I think you're saying with this install "you will be fine with regular high flow cats. and it was easy to install, you do remove all 4 factory cats." And if I was mistaken about a tuner's ability to reset "readiness" boxes, I do plead ignorance as this was an assumption I had made based on previous experience and I've never claimed to be a tuner myself (just wish I had the time and ability- but alas I too am an oldman without your acumen). And P.S. I don't know what AFAIK means. Can you illuminate? Course I guess I could Google it. Last edited by Ventmaster; 08-31-2019 at 06:29 PM. |
08-31-2019, 03:58 PM | #18 |
as far as I know....
I think you will be fine on an a non-sniffer smog check as long as you have working cats. Yes when you put in LT (with or without cats) all 4 factory cats will be removed. It is possible with some welding skills to reuse the back two cats and weld in bungs for the rear 02 behind the factory back two cats. But that may be for another thread. Software can turn off check engine lights, this in general resets smog read monitors to "not ready".... then you have to drive the car a bit to get the monitors to become ready. EPA law prevents anything that I know outside of the dealer and / or GM to be able to reset a ready monitor.
08-31-2019, 06:31 PM | #19 |
Thank you sir!
09-01-2019, 09:32 AM | #20 |
I have never heard of E-Check in Ohio before reading this post. I did a quick search and there are only 7 counties around Cleveland where it is required. Glad I live in one of the other 81 other counties. http://www.ohioecheck.info/Home/Index
09-01-2019, 11:25 AM | #21 |
The new RapidScreen vans travel throughout Northeast Ohio and can scan your car as you drive by to diagnose your exhaust system. If your vehicle is really clean and has passed RapidScreen's emissions qualifications, you'll receive a notification in the mail. This is available for about 5% of vehicles that are really clean. For the few vehicles that pass this, they will not be required to go to an emissions testing facility.'
You can bet that if your car fails you will get a nasty gram..... Welcome to California. For Texas and I don't think it is a county thing, you can report ANY car to the DMV for "smog" vilolation... I used to own and race diesels... ask me how I know.
09-01-2019, 01:20 PM | #22 | |
Drives: 2018 Camaro SS 1LE Join Date: Sep 2018
09-01-2019, 01:22 PM | #23 | |
I can’t believe our tax money pays for this tree hugger shit. |
09-01-2019, 01:22 PM | #24 | |
09-01-2019, 01:24 PM | #25 |
Looks like it’s OBD-II only. Would I pass?
09-01-2019, 06:35 PM | #26 |
If it is OBD-II only, according to Oldman, even though the tuner can tell the ECM to ignore it and not create a CEL, if they plug into your OBD-II port it will tell them "cats not ready" - all four of them!
Our exhaust system is one piece. Keep it and if you get into an "issue", bolt it back up and take it back to the emission station. They give you a reasonable amount of time to remedy problems with inspections. It may be helpful to get longtubes with O2 sensor bungs included for visual inspection that might prevent an actual OBD plug-in. |
09-01-2019, 07:42 PM | #27 | |
As long as the rest of your emissions system reports as “ready”, you can set your O2 sensors to “report no errors” and still pass, since you’re allowed one “not ready”. You definitely want your long tubes with O2 sensor ports regardless.
09-01-2019, 08:14 PM | #28 | |
I should also mention again, this is a Federal Law... you are addressing local enforcement, that does it NOT make it legal at all. Just that you pass whatever enforcement at your local. As an example, you drive your recently inspected ride to CA, and they impound your car at the local curb side sniffer test... bummer cause it is a Federal Law that you can't tamper with the cats for ANY REASON........ The rear cats are not monitored... correct.
