Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Exterior Parts & Accessories
Old 06-22-2016, 03:55 PM   #1
southerncarparts
southerncarparts's Avatar
Drives: 2009 Corvette Z06
Now available from SCP: 6th Gen Camaro LT LS ACS T7 Front Splitter 48-4-007
2016 6th Gen Camaro LT LS ACS T7 Front Splitter 48-4-007
The latest Gen6 Camaro is simply stunning, won't take long to realize that a new front splitter will set it to a new level. Not only will it add an extra visual dimension to the car’s sleek build, but it will add aerodynamics and guile at high speed to a vehicle that already handles like a dream.
Available in a black primer finish, or Carbon Flash Metallic Black.
Features:
- Improved frontal airflow management
- Manufactured in an OEM-validated RTM composite material
- Use of OEM mounting points for simple installation.
For those that love to adorn the car themselves. You will be pleased to know that installation is less than 15 minutes; the ACS-T7 Splitter is installed using the OEM mounting bolts . Fits all 2016 Camaro I4 & V6 front fascias.
Winglets have over the last few decades been used by both commercial and corporate jets. Jet designers have long known that airflow off the end of a wing caused drag. With the implementation of the winglet airflow was improved and planes moved more efficiently. Same principal applies to the latest Corvette Winglets / Deflectors line.
Application Guide
- Camaro I4, V6 2016-17 Coupe, Convertible
Click here to order: 2016 6th Gen Camaro LT LS ACS T7 Front Splitter 48-4-007
southerncarparts is offline   Reply With Quote
Old 03-06-2017, 03:31 PM   #2
southerncarparts
Thank you for the orders!
Old 08-24-2017, 11:39 AM   #3
15cammedSS
15cammedSS's Avatar
Drives: 2015 2SS....white
Do you have these in stock or are they drop shipped?
2015 Summit White 2SS/RS with NPP.... Roto-Fab intake....Phastek lowering springs....BMR strut brace....custom cut blower cam and tune by Matt Sorian.....@MSTuning...BTR valve train....stainless power longtubes with HF cats....Phastek supplied
15cammedSS is offline   Reply With Quote
Old 10-17-2019, 09:46 AM   #4
southerncarparts
