06-27-2016, 08:48 AM | #1 |
Motorhead
Drives: 2016 Camaro Convertible 2SS Join Date: Jun 2016
AC Drain issue I think
Well I have about 600 miles on the car now and with it being 100 degrees in the South this weekend I've noticed an issue. When driving the car back from South Carolina over the weekend my wife and I noticed water dripping on our feet while driving down the road. It seems like my AC Drain my be stopped up.
I'm called today and will be taking it in for a check in the morning. I hope this is an easy fix. Has this happened to anyone else? thanks, Phillip _____________________________________ 2016 Camaro SS Convertible Nightfall |
06-27-2016, 10:42 AM | #2 |
Drives: 2016 Chevy Camaro Join Date: Feb 2016
I have not had this happen, but most cars have a little rubber hose that connects to the bottom of the AC box under the glove box and pokes out the firewall to drain the water. If that were not installed or not installed properly this is precisely what would happen.
Whiskey |
06-27-2016, 11:53 AM | #3 | |
06-27-2016, 05:45 PM | #4 |
Motorhead
I see the dealer in the morning so I'll let everyone know what happens.
Thanks, Phil
Cars in the stable right now.
2016 Camaro SS Convertible Nighfall 2013 Dodge Charger SRT8 2002 Chevrolet Quad Cab Duramax 2012 Jeep Wrangler Rubicon BUILT, Supercharged 1969 Camaro FAKE Z28 1968 Ford Bronco Rockcrawler |
06-27-2016, 06:49 PM | #5 |
Drives: 2016 2SS Join Date: Feb 2016
Have had the same issue occur twice.
06-27-2016, 09:11 PM | #6 |
Water dripping onto your feet sounds like condensate is forming on the ductwork. If the evaporator drain were clogged, I would expect a puddle to form on the carpet around the center console. There would be no dripping onto feet, as the water would simply overflow at the low level of the drain pan.
I suppose the next question is how are you running the A/C? Windows or sunroof cracked to let humid air in? |
06-28-2016, 09:43 AM | #7 | |
Motorhead
The dealership looked and could not find a reason for the issue. Checked the drain and it was installed correctly and not clogged. It's a new car (1,000 miles), so I was more concerned of an install issue. Yes, I was running the A/C when this occurred so I believe you are right. I live in Georgia and the humidity is off the chart right now. I think it was condensate on the lines/ducts that was dripping on me. I think the mystery is solved but I'll keep an eye on it. Thanks, Phil
10-10-2017, 04:21 PM | #8 |
This just happened to me. Had AC on in very humid conditions, with window partially open.
Steve-A-Reeno
10-10-2017, 05:28 PM | #9 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
well he just said it wasn't clogged.
Ductwork should be insulated so that condensation doesn't happen. Condensation on ductwork is the perfect place for mold to grow as it tends to be dark as well. It's a shame that chevy seems to be choosing not to spend the extra couple bucks to insulate these things properly but instead spends those dollars on forcing needless crap like onstar and power seats that dont recline. Meh. |
10-10-2017, 10:39 PM | #10 |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
In a way, I bet the cold water dripping on your feet felt good in those kind of temps.
06-05-2022, 03:33 AM | #11 |
Drives: 2016 2SS 6MT Join Date: Apr 2020
Dealing with this issue now. Did anyone find a fix? Took it to a local shop. They said tranny needs to be dropped to get to the drain.
06-05-2022, 10:32 PM | #12 | |
Drives: SS 1LE, 89 TTA, 91 GTA, 91 Formula Join Date: Jul 2019
Worked on Jags, Hyundai, Nissan/Inifiniti, GM, etc, duct work in cars isn't insulated. |
06-06-2022, 06:24 AM | #13 |
Hmm. If drain clog is really the issue you might be able to get to it with an inspection cam:
https://www.amazon.com/Compatible-NI...NrPXRydWU&th=1 Attach one of those cleaning brushes for reusable drinking straws to the end and clean it that way. Last edited by ctrlz; 08-13-2022 at 07:56 AM. |
06-06-2022, 12:48 PM | #14 |
Drives: 2017 Camaro SS Fifty Join Date: Oct 2016
My 2017 does it on occasion as well.
