01-09-2018, 10:18 AM | #1 |
Drives: 2013 Camaro SS 6-Speed Join Date: Nov 2017
Looking to remove RS chrome trim on 14 ss
Anyone remove the chrome trim on the front grille and headlights?
I've seem people replace the grille with the z28 grille and it looks great but they leave the chrome trim around the headlights. I know there will be a visible hole on each side but anyone else just say screw it and removed all the chrome trim?
2013 Camaro 1SS 6-Speed LS3 All stock.. For now... |
01-09-2018, 10:46 AM | #2 |
Instagram: Sangstah
I dont think you can remove the chrome trim on the headlights because it will leave a void. Most people just wrap the trim above the headlights and delete the center for the z28 grill.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
01-09-2018, 07:56 PM | #3 | |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
I've read threads about this and they just wrap the Chrome into a different color.
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
01-09-2018, 09:27 PM | #4 |
Drives: 2015 2SS Summit White Join Date: Oct 2017
I just did the rs conversion today on my non-rs ss. No hole for me since it did not come with the hid's from the factory. (The factory rs models will have a small rectangular hole on the corner. I'm not sure how much this picture will help but this is without the chrome trim, their is a small led strip at the very top that serves really no purpose as it does not light up. Curious why gm put that there in the first place if anyone knows? anyways you only notice it if you sit down as in the way this picture was taken. I also have the z28 grill (mine came with it from the factory)
01-09-2018, 10:42 PM | #5 |
I used "black out tape" (sold at most car parts places). Took me 10 minutes and can be removed in seconds at anytime.
'14 1LE, Recaro, Cammed, Headers, Hi Flows, CAI, Tuned, 486 RWHP
https://www.youtube.com/watch?v=H57UfKCO0EY&feature=youtu.be |
01-10-2018, 12:48 PM | #6 |
I think I might try removing the trim and cover the holes with black vinyl
01-10-2018, 02:05 PM | #7 |
01-10-2018, 02:44 PM | #8 |
Here you go.
01-10-2018, 03:57 PM | #9 |
I think it looks so much better without the RS chrome trim
01-10-2018, 04:03 PM | #10 |
01-10-2018, 04:40 PM | #11 |
Drives: 2015 2ss Join Date: Jun 2009
looks great! how did you apply around the curved edges of the headlight?
2015 Camaro 2ss, NicKey Performance built/tuned |
01-10-2018, 05:04 PM | #12 |
Divided the chrome into sections, easier to handle this way. The vertical one just wraps around the back. Used a plastic putty knife to smooth it.
01-10-2018, 05:35 PM | #13 |
thanks!
01-10-2018, 05:52 PM | #14 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
When I had my '15, I plasti-dipped the chrome trim.
Tags |
grille, rs package, z28 |
