Old 01-25-2016, 09:24 AM   #1
Bassment
Drives: 2016 Red Hot 2SS M6
Very slight noise when wheels fully turned
I put 18" snow tires on and when I have them full turned right, the left wheel will make a quiet clicking sound only once per rotation, and when fully turned left, the right wheel does the same thing. I think it might be the weights in the inside of the rim clicking against the plastic piece in right by the brake rotor? What do you guys think? Just leave it? Or maybe cut the plastic piece? Or could it be something else?
Bassment is offline   Reply With Quote
Old 01-25-2016, 09:51 AM   #2
leadfoot93
Camaro Fan
leadfoot93's Avatar
Drives: 2016 Camaro 1SS Garnet Red
I'd jack up the car and spin them and see what you find.
Ordered: Garnet Red Tint coat 2016 Chevrolet Camaro 1SS, Auto, NPP
1100 Status: 8/6/15
3800 Status: 10/13/15 VIN #116519
4200 Status: 12/19/15
Delivered : 12/28/15
leadfoot93 is offline   Reply With Quote
Old 01-25-2016, 10:25 AM   #3
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Google Ackerman effect....the Vette does it all the time, so does a brand new 911......is your new tire wider than the stock tire?
https://en.m.wikipedia.org/wiki/Acke...ering_geometry
Old 01-25-2016, 10:38 AM   #4
Bassment
20 mm narrower
Old 01-26-2016, 08:07 AM   #5
Bassment
Does the 6th gen camaro use ackerman steering? Anyone else get this at max turn at slow speeds?
Old 01-26-2016, 09:46 AM   #6
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
it's not a option, it's an effect....your new tires are "skipping".
Old 01-26-2016, 10:30 AM   #7
Bassment
It's an effect if it uses ackerman steering. A car doesn't have to use ackerman steering (but most do).
Old 01-26-2016, 10:31 AM   #8
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
No it's Ackerman effect, not Ackerman steering....No car has "Ackerman steering"
Old 01-26-2016, 10:33 AM   #9
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Nevertheless, it'll be there on these tires....esp in the cold, it's much worse when tires are hard....
Old 01-26-2016, 12:55 PM   #10
Bassment
There are cars without Ackerman steering. The wheels would both turn the same angle, therefore going around turns causes the inner tire to slip and cause extra heat. Ackerman steering is just a type of geometry the car is designed to follow for steering. The Ackerman effect is the result of having ackerman steering, which causes the wheel to jump at low speeds like you said. Most cars only use partial ackerman steering so they don't get a noise. But cars like the corvette that use pure ackerman for maximum track performance don't care about slow parking lot speeds so they have the worst effect.
Yeah, it's definitely worse at cold temps with hard tires. I'm going to try it later in a muddy parking lot
Old 01-26-2016, 01:16 PM   #11
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
the ackerman effect -for chev -is to get a smaller turning radius, not any track abilities...(at least that what gm execs say at the vette fest)
Old 01-26-2016, 02:03 PM   #12
Bassment
Ah, makes sense
Old 12-06-2018, 06:25 PM   #13
camaroJD
Drives: 2019 Satin Steel 1SS 1LE w/ PDR
Bumping this old thread because I have this issue and can't diagnose it just yet.
I picked up stock LS '16 wheels and tires to put on my 1LE for the winter. I had the dealer install them today so I can take delivery tomorrow. I received a call from my salesman saying the tires wouldn't fit (which I knew was false).
The service manager showed me that the wheel weights on the 18" tires were hitting the brake shield/cooling shield when turning and made a loud clicking noise. He said the weights were the slimmest ones and recommended I trim the plastic shield about 1/8" inch once I get it home.
Has anyone else had this issue? What did you do? Would front spacers solve this issue?
camaroJD is offline   Reply With Quote
Old 12-06-2018, 07:08 PM   #14
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Good to know what its called.. i though i had bad wheel bearing or broken swaybar link.. jacked car end, took wheels off, everything tight.. continue until it gets louder .
Exactly as described, low speed, COLD tires, you get a pop or light noise from front end.
ing for grip.
http://www.motorsportsne.com/
