05-23-2014, 12:35 PM | #1 |
Drives: none (yet) Join Date: Jul 2012
Car takes awhile to start *update
I have a problem. Ever since I got my Maggie installed and tuned my car will take awhile to start sometimes. This only happens if it's been sitting for awhile, and I have no idea what is causing it. The car will crank over but won't start until after about 4-8seconds. Anybody have any insight?
05-23-2014, 12:58 PM | #2 |
Drives: 2012 SS Join Date: Sep 2012
Had a simalar problem it was a loose ground
05-23-2014, 02:04 PM | #3 |
Drives: 2010 twin turbo ss Join Date: Nov 2012
Did you change injector size? My car and a few buddies cars had to take some cranking fuel out after installing bigger injectors. It would start right up cold in the morning then after it sat for a few hours it would crank a while to start. We pulled 20-25 percent fuel out of the cranking fuel and it fixed the problem. You might try that and see if it helps
05-23-2014, 04:10 PM | #4 | |
Ted.
www.jannettyracing.com
05-23-2014, 04:11 PM | #5 | |
Ted.
05-23-2014, 07:17 PM | #6 |
here's a list of all the motor mods on my car
CAI intake catch can ported TB LT headers LS3 conversion 7.400 pushrods BTR dual valve springs GT9 cam ZL1 fuel pump ADM FPCM 80 lb injectors Magnuson tvs2300 3" sw retro catback Last edited by jake2212; 05-24-2014 at 01:12 PM. |
05-23-2014, 10:23 PM | #7 |
If you turn the key on for about 15sec and then try to start it does it start?
05-24-2014, 07:48 AM | #8 | |
There is also Some Idle control stuff that needs to be done when a cam is added to the combo. You should also consider adding ADM FPCM ZR-1 Map sensor Ted.
05-24-2014, 12:38 PM | #9 | |
05-24-2014, 12:38 PM | #10 |
05-24-2014, 04:04 PM | #11 |
05-24-2014, 05:48 PM | #12 |
We'll I was wondering if your pressure is bleeding off and the pump is taking a little long to build pressure. If its still doing it you need to get your tune looked at.
Sent from my iPhone using Tapatalk |
05-24-2014, 06:24 PM | #13 |
05-25-2014, 02:58 AM | #14 |
just did it again, turned the key for 15 sec, then cranked it and it turned right on.
