06-20-2018, 11:17 AM | #15 |
Drives: SS 6 speed of course Join Date: Jan 2016
It is a sickness, I still have my heart set on a sheet metal intake...I'd sell my soul for it. I do like the idea of dual injection and I know the MSD can also take injectors.
06-20-2018, 11:28 AM | #16 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
My guess PRAY is the air turbulance going over the throttle blade. I will know in a couple of hours as I have a OEM stock TB and am going to swap it over and test out my theory.
06-20-2018, 11:38 AM | #17 |
Drives: 2016 2SS Join Date: Jul 2016
I have since revamped my TB porting and now leave the TB blade bar alone. I think with the blade being flat there is nothing to break the air and it can cause a flat hit on the blade. I did reconfigure the actual porting though as to not lose any of the benefits from the porting. They flow virtually identical. This is by far the weakest blade motor I have ever seen from GM. Any little air variance to it and it freaks out. None of the TB's before this have been this sensitive. I have things I do in the tune to lessen it's sensitivity now as well.
06-20-2018, 07:23 PM | #18 |
Drives: 2017 1SS A8 Nightfall Gray Join Date: Feb 2017
I am also having the same surge and have a ported TB , is it ok to swap back to the stock TB without doing anything to the tune?
06-20-2018, 08:05 PM | #19 | |
It is continuing to lead me to thinking it is the BOV causing the issue. |
06-20-2018, 09:06 PM | #20 | |
2016 2SS/Hyper Blue/M6/NPP/Navi
Forged pistons Custom cut Brian Tooley Cam SW long tube headers 3" stainless mid pipe - Secondary Cat delete - High flow cats Port and polished heads-Double valve springs-platinum lifters & push rods Cam phaser limiter - DOD delete P1SC-1 Pro Charger 3.7 pulley Stage II intercooler 667rwhp 577ft lbs |
06-20-2018, 10:03 PM | #21 |
I have the race valve with the exact surge stated by the Op I was thinking he was on to something with the ported TB guess not
06-21-2018, 12:37 AM | #22 |
I heard the race valve needs the tank to be welded?!
06-21-2018, 07:03 AM | #23 |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
Oldman looking to be in 800-900 whp range, I see a fuel system upgrade in his future.
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ |
06-21-2018, 07:13 AM | #24 |
DANG IT! I was thinking/hoping that was the fix for this.
06-21-2018, 07:14 AM | #25 |
Where at and do you know why? I haven't heard this.
06-21-2018, 07:23 AM | #26 |
Yes there is welding needed to be done in order to fit the Race valve or even a Tial. The standard exit on the I/C is 1.5" and has a 2" long extension that projects off of the I/C. in order to put a larger BOV on you will need to cut the existing flange off, then enlarge the hole on the I/C and then weld a new 2" flange back on the I/C so you can run the larger 2"/50mm BOV.
06-21-2018, 09:29 AM | #27 |
Not the ported TB. Thanks for the update.
06-21-2018, 11:36 AM | #28 | |
The blower moves air based on Engine RPM but you are in control of the throttle blade opening. You have a large amount of air backing up in front of the throttle blade but the blade is barely open, this is what causes the Slinky effect or Surge. Move to the Race bypass or add a second bypass to the Drivers side or Hot side of the intercooler and your surging will go away. I prefer to run 2 as it can have more volume than 1 large one. On my YSI Camaro I run 2, 50mm Tial Q valves with 1.5 psi springs. Ted.
www.jannettyracing.com
