Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Old 12-05-2020, 05:31 PM   #1
USMC SGT
Drives: 2021 1SS 1LE
Advice for winter tires/wheels for a 1LE
I just bought a 2021 1SS 1LE and I’m looking for options and opinions on what would be best for winter wheels and tires. Was thinking about a set of SS wheels and putting snows on them or I’m open to going aftermarket also. What size wheels and tires do you recommend?
USMC SGT is offline   Reply With Quote
Old 12-05-2020, 05:59 PM   #2
shogun37
Drives: none
plenty of inexpensive 19x9.5 et22-33 or 19x10 wheels for winter use.
shogun37 is offline   Reply With Quote
Old 12-05-2020, 06:00 PM   #3
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
I went with 265/40/19 Michelin PA4 N-Spec, which are designed for Porsche, I figure they would work better with the LT1's massive torque, the size works and they were on sale at Tire Rack. They do really well on packed snow, and the car is surprisingly good on cold, dry pavement too.
I used 19 x 9.5, 20mm offset MMR wheels with a 7mm spacer and +1" ARP wheel studs up front. I cut the nose off the studs so stock wheels/lugs fit and I can also use a larger spacer for an AutoX/Track setup. You can use up to a 5mm spacer up front w/o changing studs, IMO.
Stock SS wheel + performance snows would be good, but you can't rotate so you get half the mileage warranty, at least with Michelin, and rears will likely wear faster.
Old 12-05-2020, 06:01 PM   #4
HCI2000SS
HCI2000SS's Avatar
Drives: 2018 Camaro V6/RS
I see you're out in my neck of the woods. With Michigan winters being relatively mild these last few years, pretty much any dedicated winter setup will do. Hell I even used all seasons for my first winter with no major problems
HCI2000SS is online now   Reply With Quote
Old 12-05-2020, 06:15 PM   #5
Redlinez
Shifts under load
Redlinez's Avatar
Hey Marine, Bridgestone makes the RE980AS if you go with a 295/30 front and 305/30 rear. I just did that but went with the Bridgestone S007a's as we rarely get snow and I want to see how much better it is as a daily driver over the original Goodyears. I hated how they jerk the steering wheel with road imperfections or dips.
USN 1989-1995
17 Camaro SS-1SS 6m white-traded in 3/27/20
20 Camaro 1SS 1LE- rally green metallic, PDR
Old 12-05-2020, 07:56 PM   #6
Wontspeak
Wontspeak's Avatar
Drives: 1SS 1LE
19” Michelin a/s +3 Run Flats 285/35’ that are mounted on MRR M716 10’s and 11’s
Last lap of day at Road America October 2019. Below freezing windchills.
Lap starts at 1:25 on these tires.
Wontspeak is offline   Reply With Quote
Old 12-07-2020, 04:58 PM   #7
Vaska
Drives: 17 SS 1LE
OEM 18s from 2016 up with 245/50 tires.
Vaska is offline   Reply With Quote
Old 12-08-2020, 08:13 AM   #8
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
I will tell you the BFG Comp A/S 2 are CRAP in the snow... I had them and ok with a dusting but anymore than 1/2 inch and they were junk.
2019 ZL-1 Acquired 4/23/21 at 6300 miles. Riverside Blue, A10, PDR. Traded in 2017 2SS with 6M and 32k miles. Continental Extreme Contact Sports.
Old 12-08-2020, 08:20 AM   #9
Hops
Hops's Avatar
Drives: 2019 1ss 1le, blue wrap
i went with a square 275/35-20 Dunlop DWS 06 on the MRR SS 1le replicas. Haven't really got any snow action, but that tire was ok on my 1 series bimmer.
Hops is offline   Reply With Quote
Old 12-10-2020, 08:09 AM   #10
WhiteMale
Drives: 18 SS 1LE / 21 ZL1 on order
I agree with you on that tire, was great in cold and wet but snow was a no-go. I needed a little bit of snow capability so I stepped up to the Alpin PA4 this year but no snow yet so no verdict (yet).
275/35 and 285/35 fit F/R on the 1LE OE wheels just fine and are close enough to the speedo not being off by more than 1mph.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
