02-04-2018, 01:22 AM | #85 | |
Drives: 2016 White 2SS M6 NPP MRC Join Date: Jan 2017
Thanks for the help!
2016 Camaro 2SS M6 NPP MRC, MBRP Axle-Back, Mighty Mouse Solutions Catch Can, 19" Gloss Black Forgestar F14's on Michelin PS4s
Trying to learn to drive in SCCA FS Class, check out my YouTube |
02-04-2018, 08:00 AM | #86 |
Drives: 17 ss1le. Pray headcam e85 fbo msd Join Date: Mar 2017
18 inch rear. 19 inch front auto x setup
So this is what I’m seriousl considering with the supposed new 19 inch BFg rival availability. Run 335/30/18 rear. 25.9 inch diameter and 305/30/19 26.3 inch diameter. Stock diameters for the 1le are 26.8 front 27.2 rear so .4 inch taller in the back. The 19/18 setup would be .4 shorter in the back so I was thinking of using Moreno camber plates to drop front down .5 inch to make the rake almost identical to stock
My car is a cammed ported 1le that I’m running in cam class Have the dsc controller which does help in transitions and full compressed cornering and also adjustable rear sway which I’m figuring out. I need as much tire as I can get as the motor build with a “torque cam” netted over 450 lb ft of torque for a 3200rpm spread So what do you guys think. I can’t see any reason not to try it other than chipping the crap out of my paint |
02-04-2018, 09:25 AM | #87 | |
Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
That’s classified! Lol jk. Front the car only gets 2 degrees and that’s what I’m at with a small amount of toe out in the front. I tested the 265 late in the season up front. They wore soooo much better! It was insane. They don’t deflect as much so that center rib doesn’t get all tore up. Some people believe the larger the tire the better and I do agree with that but expense wise... sometimes it make me think lol.
#53 F Street
2022 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 2022 Rapid Blue 1SS 1LE 2019 D Street national champion (2019 civic Type R) |
02-04-2018, 10:20 AM | #88 | |
Drives: 2017 Camaro SS Join Date: Sep 2017
Jeff Wong
ESP Camaro |
02-04-2018, 02:40 PM | #89 |
18inch clear brakes ok but hit the spindle with 10.5 inch wide wheels is what I’ve read from road race guys that have tried them
02-04-2018, 05:03 PM | #90 |
Drives: 2017 SS 1LE Join Date: Mar 2016
You could get camber plates and run low knuckle camber like -1, and another -2 on the camber plates. That would allow the 18"s.
IG: @NC_M1SS1LE
02-04-2018, 07:48 PM | #91 |
Good point but if I go that way with the bfg then the front (25.4 - .5 drop with camber plate= 24.9)has a full 1 inch drop compared to the rear(25.9) and I am worried about that much change in f/r weight distribution upsetting the balance of the car. This thing works so well stock it’s hard to mess with but... here I go anyway
02-05-2018, 09:58 AM | #92 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
What seems to happen is people look at the amounts lowered and think in terms of how much added weight it would take to lower the car the same amounts. It doesn't work that way (I'm thinking closer to 53.0%/47.0% moving to something like 53.2/46.8 . . . which I suspect is less than the change in weight distribution you get going from a full fuel tank down to a quarter tank, which can and sometimes does happen on the track). Maybe Formula 1 worries about such tiny effects , but it's a waste of time for us to. Norm
'19 WRX 6M (the family sedan . . . seriously) Last edited by Norm Peterson; 02-18-2018 at 06:36 AM. |
02-14-2018, 04:56 PM | #93 |
Anyone at the Fort Meyers Pro Solo looking for a co-drive? Might be in town that weekend. I don't have much to offer but I'll try to be gentle on your tires.
Jeff Wong
ESP Camaro |
02-14-2018, 05:30 PM | #94 |
Final testing done with the current setup on a completely opposite surface at Auto Club Speedway, which is a really low grip asphalt surface that has huge voids probably due to age/use. I will say I struggled a lot and wasn't disciplined, especially under braking. Saturday's practice, I blew the same braking zones in probably 3-4 different cars. Sunday (the championship day), I told myself not to be as eager but still left time out there, especially under braking. Managed to somehow PAX decently well; Brian Peters took one run in my car and beat me by a tenth (my raw time), that would have had top pax. The course didn't allow him to adapt as early because the higher speed transitions were down hill/off camber, he most likely would have been a lot faster.
2/10-2/11 Southern California - Autoclub Speedway F-Street 2017 Camaro Bridgestone RE-71R AAA Speedway Practice 2/11 Brian F-Street 2017 Camaro Bridgestone RE-71R AAA Speedway Practice 2/11 Jeff F-Street 2017 Camaro Bridgestone RE-71R AAA Speedway Practice 2/11 Nicole
Jeff Wong
ESP Camaro |
02-14-2018, 09:14 PM | #95 | |
#53 F Street
02-16-2018, 05:05 PM | #96 | |
We generally make it out to Spring Nationals, the plan is too this year.
Jeff Wong
ESP Camaro |
02-16-2018, 09:04 PM | #97 |
Awesome! Should be a fun class.
#53 F Street
02-17-2018, 03:04 PM | #98 | |
Drives: 17 1SS 6MT, 09 Tacoma TRD Sport Join Date: Nov 2017
