01-13-2018, 02:00 PM | #1 |
Drives: 2014 ZL1 Join Date: Jul 2016
PLX DM-6 Wideband, I should have known better
Finally put some gauges in the car an Aeroforce and PLX Afr in a center speaker pod.
I didnt like the look of the AEM or others and this one looked expandable. What I got was a gauge that looks good when it initializes but only initializes 1 out of 3 times. Tech support is only by email and there is no number to call unless they call you 4 rounds of tech troubleshooting and the fianlly are inclined to replace than quiet, no rma no call, no we ll ship then you ship yours back. I think they want me to rip mine out, ship and they analyze, WTH |
01-13-2018, 04:22 PM | #2 |
Drives: 2012 ZL1 Join Date: May 2017
Thanks for the heads up. I try to buy stuff like that from Summit or the like just for that reason.
01-13-2018, 04:33 PM | #3 |
I may get one from amazon, they stand by the product, or look for a different vendor if this isnt fixed soon. Jegs carries this but 100$ more than buying direct
01-14-2018, 08:47 AM | #4 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Never had an issue with my Aeroforce gauges....
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
01-14-2018, 09:45 AM | #5 |
Except aeroforce has a known voltage drop when external datalogging, so the gauge has to be disconnected when a laptop is hooked up. Also its much to busy for an afr reading.
Still looking, if they dont send a new unit then I will use the innovate dlg-1 dual wideband DB |
01-15-2018, 09:47 AM | #6 |
Zietronix... only way to go. I have the hacker mod in mine and that is the hands down best AFR gauge I have seen or used.
01-16-2018, 08:37 PM | #7 |
What a POS company. Rather than send out a new gauge and or a sensor box with my credit card on file they want me to rip everything back out and send it back for "analysis and repairs". I know I have gotten used to Amazon service but come on the power wires and sensor test good, send me some active components. Since its intermittent I can already see the report "no problem found"
What a joke |
