01-31-2022, 01:23 PM | #1 |
Drives: 2018 1SS Join Date: May 2021
Keep the TSP cam...or not? Advice needed...
So I bought a 2018 1SS 6-speed, and it already had some mods:
*TSP VVT-2 Cam, Specs: 231/235, .645"/.635", 116 LSA *all other camshaft related upgrades, LS7 lifters, pushrods, valve springs. *TSP 1-7/8" Longtube headers *TSP non-catted x-pipe *Roto-Fab CAI *Mishimoto Catch-can *Flex fuel sensor The engine is otherwise stock. And the car was of course tuned for these mods, I know the shop owner personally. With these mods, the car made 485rwhp on 91 octane. It was never tuned on E because the sensor was added afterwards. My goal is to make 600+rwhp N/A on E. My plan on reaching that goal is to add Factory Mast CNC heads (large valve option), Cometic .028 head gaskets (to bump compression to 12.27:1), MSD intake manifold, and 103mm TB. And then of course to be re-tuned on E. Now this is where I'm seeking advice: Will the existing TSP camshaft get me to my goal or do I need to go with a different cam? It would be great to be able to just swap out the heads and add the intake & TB and go...but if the cam needs to be replaced with something different I'd rather do it while I'm already that far into the engine. Also, is a 103mm TB necessary to reach my goal or would say a ported 95mm LT5 unit be sufficient? Any other thoughts or advice on the combo I'm thinking of would be appreciated too! |
01-31-2022, 02:35 PM | #2 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
you won't reach it on that cam, Race proven motosports seems to hit where youd like to be easily with their cam and head setup. I had the TSP VVT3 cam and i was at 560 wheel and 500 torque. with ported msd, heads, and 103 TB to include everything else you currently have.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
01-31-2022, 02:42 PM | #3 | |
01-31-2022, 03:29 PM | #4 | |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
01-31-2022, 03:47 PM | #5 |
Fair enough. From what I'm calculating, If I milled the heads ~.015-ish combined with the thinner head gaskets, compression should end up at 12.8:1...now just need to figure out a solid choice on a camshaft that'll do the trick.
01-31-2022, 05:38 PM | #6 | |
Drives: like an old lady Join Date: Jun 2012
edit: also i don't think you'll see 600 on that dyno. doesn't appear to be near as generous as RPMs uncorrected dyno.
01-31-2022, 06:10 PM | #7 |
01-31-2022, 06:26 PM | #8 |
Drives: 2019 2SS Camaro Join Date: Apr 2012
If you do the cam, while your in their I would do pistons and rods
02-01-2022, 09:24 AM | #9 | |
And if I don't see the magic 600 on the dyno, I'm not that worried about it. I realize a dyno is just a tool. I'm mainly looking for a solid 100rwhp gain over where it sits currently. |
