12-19-2021, 09:02 AM | #1 |
Drives: 2016 Camaro 2SS & 2011 Camaro 2SS Join Date: Dec 2021
416 LT1 Procharged Cam
Hello everyone, I currently have a 416 LT1 with a F1A-94 procharger that made right at 700RWHP on about 14lbs of boost. I have the MAMO MSD, nick Williams 103. My current fuel system is the LT4 System and injectors with a DSX low side pump.. my motor is currently shot and rebuilding it here soon at the shop. I was wondering I could only run E40 max on that old set up. My old cam was a custom cam with these specs.
.603 .594 214 228 118+4 32% overdrive If I went with a bigger cam and got a 40% or 38% fuel lobe do you think i would be enough to get to the full E85 mark with that? Or do you think the power I would pick up with a bigger cam I could then run less boost and make it there? Just can’t justify getting the XDI injectors and fuel pump for 6k just to run full E and only be able to run up to 800 RWHP.. And I DO NOT want to add meth injecton.. any input would be great thanks!! |
12-19-2021, 09:11 AM | #2 | |
Read some of KingLT1’s posts on this board about fuel system sizing. You don’t need to run full E to make big power, E50-E60 will get it done with a significantly lower strain on the fuel system. There’s a crap ton of great info on sizes of pumps & injectors and what they will support for power at different E ratings. But you’re going to have to make an investment in the fuel system if you want to make big power. Either: 1. Port injection 2. XDI setup 3. LPE BB HPFP and +52% injectors
12-19-2021, 09:21 AM | #3 |
I agree it should be making more power but I think it’s because the motor was built for 30lbs of boost and there was a shit ton of blow by and it just wasn’t efficient.. I had a valve drop and destroy the block.. so I am now going with the Frankenstein head package so I should pick up some power there also.. just weighing out different options
12-19-2021, 08:13 PM | #4 | |
Drives: Camaro Super Sport, Six on the Stik Join Date: Jul 2021
What caused the Valve to fail? The valves should handle that power with no problem is what I'm thinking. |
12-20-2021, 09:01 AM | #5 |
The factory valve seats/guides in LT1 heads are prone to failure when you run a aftermarket cam and heavier valve springs. If one plans on using stock castings then it would be wise to have the seats/guides reworked. Plenty of info out there supporting this. TSP has a disclaimer right on there website about it.
2016 NFG 1SS A8
12-20-2021, 06:17 PM | #6 | |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
12-20-2021, 07:37 PM | #7 | |
12-20-2021, 07:37 PM | #8 |
12-21-2021, 09:15 AM | #9 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
so i have a custom boost cam by pray, its bigger then his stage 2 he offers. On 93 i made right at 800, i went 50 percent 93 and 50 percent e85 and make a good amount more then 800. again this is now with meth but i feel like you definitely should of made more then 700, i'm making over 800 on 12 or 13 pounds. i would consider meth, helps a ton, just my 2 cents.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
12-21-2021, 05:48 PM | #10 | |
Drives: SS 6 speed of course Join Date: Jan 2016
There is no E85 in Hawaii so I really don't need the LingenP injectors. If I new I would end up in a farm in Hawaii with no E85, I probably would have done an 8 injector meth route. ie dual inject.
12-21-2021, 05:51 PM | #11 |
IMO, the valve seat issue is partially caused by cams with too steep of a ramp vs lift.
01-04-2022, 07:03 AM | #12 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
I see you're in Nebraska. Who out here does your tuning?
01-11-2022, 12:41 PM | #13 | |
To the OP, 6K for fuel system is in my opinion built into the cost. You gotta pay to play. I felt the 6K plus I put into the fuel system was well spent, just like the 600 bucks to put real valves into the head and I'm at 7 to 12 PSI depending on fuel and exhaust. Currently I'm at 6 PSI on a 4" pully stock headers and custom cats and 3 total mufflers.
