05-15-2020, 06:44 AM | #1 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
RAM slave cylinder
Curious if anyone is running a RAM slave cylinder. I did some searching but didn't find much. If you have one or used one. Let me know your experience with it. I am looking to swap mine out when I swap engines. I currently have the OEM slave with the Monster bearing support. Thanks y'all!!
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come. |
05-17-2020, 06:51 PM | #2 | |
Onyx_Z7 <— Instagram
Drives: 2013 2ss 1le Join Date: Aug 2014
05-17-2020, 09:20 PM | #3 | |
SomeguyK
I've done basically everything you can do for the clutch. I'm looking to make some serious power in the near future. So I am pulling the engine again. Figured I would put a Ram or Tilton adjustable slave in. I am also thinking about going from the Mcleod twin disc to RPS triple. I currently have the OEM slave with the monster billet bearing support, so no worries about plastic melting.
More to come. |
05-17-2020, 09:45 PM | #4 | |
05-17-2020, 09:45 PM | #5 | |
05-18-2020, 05:38 AM | #6 | |
SomeguyK
More to come. |
05-18-2020, 02:50 PM | #7 | |
05-18-2020, 04:20 PM | #8 | |
SomeguyK
Dood, that sucks about the clutch. What slave were you using with it? I know it has to be setup just right.
More to come. |
05-18-2020, 04:51 PM | #9 |
Using stock gm slave at the time. When my stock slave blew and killed my stock master I switched over to the tick billet master and ram slave no issues since and luckily my ACT clutch was fine
05-18-2020, 05:15 PM | #10 |
SomeguyK
Were you using the RPS bearing on the OEM slave?
More to come. |
