Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 08-25-2010, 11:07 PM   #15
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Yep.
$128 on their site. Going to keep on looking...see what I can come up with. Thanks!
TAG UR IT is offline   Reply With Quote
Old 10-07-2010, 02:14 PM   #16
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
thanks for this info Tag. . . I myself had the same scare.. . Last Lap the 4th time out. . . I was lucky enough the brakes went out on my cool down lap. . .
franknbeans is offline   Reply With Quote
Old 10-07-2010, 02:20 PM   #17
13 ZL1
13 ZL1's Avatar
Drives: 2013 IOM ZL1
I have one of these and it works pretty well. I am not sure if there are any issues using it with ABS systems though.
http://www.summitracing.com/parts/MVP-0250/
13 ZL1 is offline   Reply With Quote
Old 10-07-2010, 11:53 PM   #18
TAG UR IT
TAG UR IT's Avatar
Crazy! Last lap, just like me. Well, I'm sure the DOT 4 would be a great way to go. It's compatible with DOT 3 and you might even be able to get the dealer to change it out for you. Tell them it's "just in case."
Really, there is no difference other than wet/dry boiling points. In other words, DOT 4 can withstand a little more braking and heat. It's good stuff. Super Blue
I needed to get one of those. I just had the dealer do it and they used pretty much the exact same thing.
Old 10-08-2010, 09:02 AM   #19
WadeWilson
How U Doin?
WadeWilson's Avatar
Drives: 2014 CTS-V Coupe
Originally Posted by TAG UR IT View Post
Happy to help.
Now....I'm thinking of upgrading to stainless steel brake lines. (Honestly, losing my brakes like that kinda got me prettttttty damn nervous. I am NOT going to let that happen again!)
You won't regret it. I upgraded to Goodridge G Stop SS lines as well as having Motul Racing brake fluid put in. It's DOT 4 rated with a wet boiling point of 421 and dry boiling point of 594.
WadeWilson is offline   Reply With Quote
Old 12-12-2010, 10:26 AM   #20
TAG UR IT
TAG UR IT's Avatar
WWWWWOOOOOOOOOOOOOOOOOOOOOO
HOOOOOOOOOOOOOOOOOOOOOOOOOO
Got my MTI stainless steel brake lines in as a Christmas present from Mrs.Tag! Now...to replace and bleed those brakes once again...lol
Old 12-15-2010, 10:17 AM   #21
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
I have one like this and I used it on my 4th gen which had ABS. I never had a problem.
I also used super blue.
Worked great.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Old 03-15-2011, 09:47 PM   #22
gotroost
gotroost's Avatar
Drives: 2021 Crush ZL1 1LE
I'm sold. Going with Super Blue DOT 4 before C5Fest II. How much does it take to flush the old stuff out of the sytem? Owner's manual doesn't have anything about brake fluid capacity.
gotroost is offline   Reply With Quote
Old 03-16-2011, 11:14 PM   #23
TAG UR IT
TAG UR IT's Avatar
We used just one bottle ...$14 and we were good.
Old 03-17-2011, 06:57 AM   #24
Dr Jkel
and MR. HYDE
Drives: 2010 2SS RJT/BLK 6Spd Man
One other point for those who may not know ( I sure didn't and had to be told) If you are doing any type of track events and you are heating up your breaking system you need to be careful when you are finished and DO NOT APPLY THE EMERGENCY BRAKES it has a tendency to warp your rotors.
I do not know if this will actually warp your rotors but this is what I was told by a track instructor and didn't want to find out the hard way.
Great write up about the fluid, and brake line, glad I changed my lines, now need to change my fluid.
Dr Jkel is offline   Reply With Quote
Old 03-17-2011, 10:06 AM   #25
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
I recently used Super Blue in my bike, I liked it and highly recommend it as it makes flushing very easy. Plan on doing the camaro soon.
Cheers
K
Moriartii is offline   Reply With Quote
Old 03-18-2011, 09:02 AM   #26
TAG UR IT
TAG UR IT's Avatar
Made that a little larger for you...lol
When you are on the brakes as much as you are in a road course, they will super heat becoming extremely hot. Put that parking brake on and you are talking about welding metal together. Yes, it can warp it.
Do not EVER put on that parking brake!!!
Old 03-18-2011, 10:09 AM   #27
BowlingSS
BowlingSS's Avatar
Cheers
K
I used Super Blue in my 4th Gen. I will be flushing my 5th Gen after getting more miles on it. I wonder what GM puts in the system?
Bill
Old 03-18-2011, 12:09 PM   #28
gotroost
gotroost's Avatar
Thanks! The fluid should be here in a few days and a found a reputable local shop that will do it for a reasonable price.
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 09:17 PM
ROTORA BIG BRAKE KITS 4-12 PISTONS/ 15" & 16" ROTORS SPECIAL ADKINS PERFORMANCE Suspension / Chassis / Brakes 0 08-03-2010 12:08 PM
