08-10-2020, 09:33 PM | #1 |
Drives: 2018 Camaro 2SS redline Join Date: Jul 2018
Wiring question
I have a 2018 2SS redline and I was doing a cleaning of the engine bay and I noticed a wired had been chewed by a mouse.
Can anyone tell me what this wire is Photo attached Thank you in advance |
08-11-2020, 09:53 AM | #2 |
Can you do a closer photo?
Looks like 2 wires. I think maybe connection to evap canister purge solenoid valve. |
08-11-2020, 11:06 AM | #3 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
Hard to tell from that photo being so far away...get a pic closer in, might help others id that
08-11-2020, 01:36 PM | #4 |
Drives: 2017 Camaro 2SS Join Date: Mar 2019
I bet you're right. Weirdly, that same wire/harness was jacked up on my car, noticed it after I bought it. I procrastinated fixing it until it threw a CEL. The dealerships all carry the plug harness for this if it needs replaced...
Gary
2017 2SS A8 White, Bolt-Ons, Prayed Upon |
08-11-2020, 04:43 PM | #5 |
It’s two blue wires into a black plug but I couldn’t release it very hard to get at as it sits under intake manifold. I was able to wrap it with electrical tape just wondering what wires were for if I run into any issues
Photo attached pointing wire out |
08-11-2020, 10:28 PM | #6 |
Definitely the evap solenoid valve. If you wrapped it and you're not getting a CEL, I figure you're good to go...
Gary
08-12-2020, 08:55 AM | #7 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
Hit with a dap of solder if the wires are damaged then wrap it in shrink wrap tubing and heat seal to keep from corroding. Wish they would get rid of soy based sheathing. Permatex even makes a liquid electrical tape if hard to reach.
08-12-2020, 10:48 AM | #8 |
I don't know how he'd get heat shrink around that without disassembling the connector.
I would do electrical tape with a cable tie around it to keep the tape from unraveling. Kind of a warm area there. Since he took manifold off for "cleaning the engine bay," I would assume he will do the same every so often and can replace the zip tie if it cracks. |
08-14-2020, 09:14 AM | #9 | |
Drives: chevrolet camaro Join Date: Jun 2020
It's hard for me to see anything. Maybe that's just me. Last edited by jamessw; 08-26-2020 at 01:44 AM. |
08-14-2020, 10:17 AM | #10 |
Wait! Here is a "closer" photo:
08-14-2020, 10:25 AM | #11 |
Drives: 2016 Camaro SS Join Date: Jan 2019
Mine was the same way, I wrapped it in electrical tape. The foam padding near it also looked like a piece was ripped out.
2016 Gloss Black Camaro 1SS, A8, MRC, 6-Piston BBK
Whipple, LT4 fueling, AlkyControl, Kooks, Borla, Roto Fab, Mightymouse, aFe, Apex, C7 Carbon, etc... |
07-03-2021, 04:56 AM | #12 | |
Drives: 2017 2SS F1FTY Join Date: Feb 2020
