Old 11-09-2016, 05:44 PM   #1
cooper1965
Coopers Camaro
cooper1965's Avatar
Drives: 18 Flex Fuel LTG
H
Old 11-09-2016, 06:51 PM   #2
LSmith353
LSmith353's Avatar
Drives: 2015 Ultimate Track SS
I'm running 20x10 with +25mm offset on the front with 285/35's. I have no issues. Based on the factory offset on the rear at +39mm (and assuming my math is right), you would need a 5mm spacer to achieve the same backspacing (or clearance) I have. In my opinion, a 5mm spacer is plenty safe for street duty. I would not track it or be overly aggressive with them. However to get the 15mm "push" out towards the fender you want, you would need 15mm more spacing bringing the grand total to 20mm. I personally would not do this, but I know many have.
2015 2SS Ultimate Track Camaro
https://www.racingjunk.com/news/2014...ack-camaro-ss/
2016 2SS M6, MRC, NPP, Nav, Sunroof -- SOLD
2010 2SS/RS M6 -- SOLD
LSmith353 is offline   Reply With Quote
Old 11-10-2016, 12:45 PM   #3
PK Auto Design
PK Auto Design's Avatar
Drives: 2017 Chevrolet SS 1LE
Factory is
20 x 8.5 front, +25mm offset
20 x 9.5 rear, +39mm offset
PK Auto Design is offline   Reply With Quote
Old 11-10-2016, 01:03 PM   #4
Captain Obvious
^Name^ | Things I Say -->
Captain Obvious's Avatar
Drives: 2016 2SS Convertible, Hyper Blue
You didn't say if your starting point is the 18 or 20 inch factory wheels, so here's both:
A 10mm spacer would put the outside face of the stock 9.5 wheel 16 mm further out than a stock 18x8.5 inch wheel.
A 15mm spacer would put the outside face of the stock 9.5 wheel 14 mm further out than a stock 20x8.5 inch wheel.
http://www.wheel-size.com/size/chevrolet/camaro/2016/
http://www.1010tires.com/Tools/Wheel-Offset-Calculator#
Captain Obvious is offline   Reply With Quote
Old 11-10-2016, 06:11 PM   #5
LSmith353
LSmith353's Avatar
He's right. That's what happens when you do math in your head instead of writing it down..... I shouldn't have added 15 to the 5. 15 is all you need. Still a pretty thick spacer. Stock studs will be too short to get the recommended 7 full turns.
