03-23-2012, 03:13 PM | #1 |
Oil catch can - first drain
OK so today I decided to drain my oil catch can for the first time after about 1000 miles. I caught a lot more than I thought I would. The cup in the photo is 3 oz in size. I filled it to overflow and then caught probably another 1 - 2 oz. This first 1000 miles does include all the WOT runs on the dyno to tune the mods you see in my sig. And after that - while I have not beat on it every time out I have run it up the gears ( 1-2-3) at WOT about 8 - 9 times enjoying my new power.
The oil I caught looks and smells like used oil. Nothing foamy or gasoline smelling about it. No unusual crude in it - just plain old oil. Thoughts? About right? Too much? Who knows?
03-23-2012, 03:16 PM | #2 |
ace5.org
Seems like a lot for just 1000 miles, however be glad that thing is working!!!
Stock...For Now.
03-23-2012, 03:33 PM | #3 |
Drives: 2017 Corvette Grand Sport 3LT Join Date: Oct 2010
I'm glad I got one - I gotta empty 4oz outta mine every 500 miles.
03-23-2012, 03:33 PM | #4 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
May not be too much if you are pushing it, I would expect more under a load.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
03-23-2012, 03:43 PM | #5 |
Drives: 2011 2SS green w/black rally strips Join Date: Feb 2011
Well you do have more pressure with the new oil pump.
2011 2SS SGM M6 675 RWHP 618 TQ
CAI air induction, ARH 1-7/8 Headers, high flow cats, X-pipe, Whipple Super Charger 10 lbs of boost Stage 3 blower cam and DMH cutouts vengeance EFI Live tune pfadt stage 2 suspension. Drop springs and sway bars Granatelli 1G suspension package RX Catch Can |
03-23-2012, 04:27 PM | #6 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
That is a bit much, but all motors are different depending on how well the rings seated during breakin.
But, be glad that is NOT going into your intake air charge......the can is doing its job and even though it is a direct competitors it is one we endorse and have tested plenty. Great can and the proof is right there. |
03-23-2012, 04:31 PM | #7 |
I will be adding one, I have 6000 miles on my car. Would I have to pull the intake manifold on it and clean it out or will I be fine since I am adding one?
03-23-2012, 06:06 PM | #8 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
I might get ~2 oz after 4k miles. I drive the car very hard most of the time.
Must have good seated rings...put the car to the floor on the way out of the dealership when I bought it lol. |
03-23-2012, 06:51 PM | #9 |
Drives: 2012 2SS/RS M6 Join Date: Jan 2012
Just drained mine after 1500 miles and only had a fraction of what the OP got out of his...must be one of the lucky ones!
Street Scenes billet grille (upper and lower)
Cold Air Inductions intake w/MPD gasket/seal kit MPD cowl induction hood RX Catch can Edelbrock shorty headers MSD wires Custom cat-back w/GMPP exhaust Hurst short-throw shifter GMPP splitter and high wing spoiler Lloyd's custom "SS" mats Showstopper under hood accessories |
03-23-2012, 06:55 PM | #10 | ||
Not sure I follow completely. Can you say a little more? Not sure how a Hi-Vol oil pump affects blow-by into the crankcase and then on to the catch can. Quote:
I did nothing special for break in. Just drove it. Didn't keep it under 4k rpm for ther first 1500 miles. Also didn't rip the gears every time out. I did jump on it early on when the oppotunity and timing felt right (1-2-3 WOT runs). I also realized I used the wrong starting mileage for my calculation - I actually had 1400 - 1500 miles on the catch can. So, thats a little less oil caught per mile than I originally thought.
03-23-2012, 10:18 PM | #11 |
Drives: 2010 Camaro L99 Join Date: Oct 2009
You can use Seafoam spray in the intake threw the TB. Works well.
2010 L99
vararam intake, Vmax TB,Vmax Intake,TSP VVT 3 Cam,TSP underdrive pulley,Yank 3600,TM Cooler,ARH 2", High Flow cats, X-pipe, GM Pro mufflers, RX Catch Can,160 stat, BMR Trailing,toe,Cradle insert, Diff. Bushings, End links, Spohn-LCA's (Touring)Wheel spacer's. 422 rwhp Mustang Dyno http://www.youtube.com/watch?v=AaFNAhCL7Os |
03-25-2012, 12:31 PM | #12 |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
In my Elite catch can I got 1/4" of oil in 1000 miles.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
03-25-2012, 12:54 PM | #13 |
You can reach inside the IM opening with paper towel and get most of the puddled oil out and the rest should work its way through. Seafoam works well also but you should be fine just blotting up what you can reach.
The Elite is also one of the best on the market....and we test and dissect them all. Cant go wrong with either of those. |
03-25-2012, 10:07 PM | #14 |
Drives: '11 Camaro 2SS/RS LS3 Join Date: Jan 2012
Seems like alot, may just be doing a better job than other catch cans? Maybe it's the new HV oil pump? I would like to know more also.
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Everything LS3/L99 Oil Pumps | ztsmith86 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 29 | 08-29-2015 03:11 PM |
Elite Engineering PCV Oil Catch Cans | Instock | Best Prices with Free Shipping! | JDP Motorsports | V8 Bolt-Ons & Tunes | 137 | 08-13-2014 03:06 PM |
This is why you get a catch can!!! | BaylorCamaro | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 46 | 12-14-2011 08:52 AM |
Can we use the catchcan made for the G8? | HaZe_X | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 16 | 05-05-2010 10:35 AM |
synthetic motor oil? | bigd1276 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 71 | 01-29-2009 12:28 PM |
