Old 01-15-2017, 10:12 AM   #1
craigss50
craigss50's Avatar
Drives: 2017 Camaro SS Fifty
Inside "Bubble" in fabric
I sometimes get what I can only describe as a bubble in the headliner after raising/lowering the top. When it does it I can reach over and tuck it back into the side rail. Don't want the dealer to replace or take the top apart to fix it fearing they make it worse. Anyone else have this issue?
craigss50 is offline   Reply With Quote
Old 01-15-2017, 10:27 AM   #2
LibertyHill
LibertyHill's Avatar
Drives: 16 2SS 6MT NPP MRC / 15 K1300S
Pic.
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC
LibertyHill is offline   Reply With Quote
Old 01-15-2017, 11:40 AM   #3
camaromike77
camaromike77's Avatar
Drives: S O L D
Originally Posted by LibertyHill View Post
Pic.
Yes. A pic would help. I have not noticed any in mine.......
Club F1FTY
Old 01-15-2017, 12:47 PM   #4
craigss50
craigss50's Avatar
This is what it should look like:
This is what it looks like when the issue is present. Note that the seam is showing. That seam should be tucked under the plastic trim piece as shown in the top pic.
Old 01-19-2017, 06:49 AM   #5
LibertyHill
Dealer service is always a last-ditch resort for me due to the strong possibility of the car being worse-off than it was before. In your case I might try comparing the two sides to see what the difference could be, or maybe a small piece of non-adhesive hook velcro would stick to that material and anchor it better behind the trim so it stops creeping out?
Old 01-19-2017, 06:53 AM   #6
craigss50
craigss50's Avatar
Thanks for the reply. I will partially raise the top to see if that will work. I do know that there is an elastic band that is suppose to keep it in place so I am thinking it needs to move.
Old 01-30-2017, 05:51 AM   #7
classicrockr
Pills are for Pansies
classicrockr's Avatar
Drives: 2023 2SS Red Hot Vert Camaro
Had this happen al the time in my 5th gen, but it never caused any premature wear issues. Eventually I just accepted that it was there.
classicrockr is offline   Reply With Quote
Old 01-30-2017, 06:24 AM   #8
craigss50
craigss50's Avatar
I took it in for an oil change and had the dealer look at it. They adjusted the top. I am hoping it is fixed.
