01-21-2020, 04:53 PM | #1 |
Drives: 2017 Camaro ss Join Date: Jan 2020
Issues with a 6.2L injen cold air intake
Do you any of you guys have a injen cai for your ss? Have you guys run into a check engine light? I purchased this assuming I didn’t need a tune , which it said it doesn’t need one. Didn’t check the code yet but could it be my modified MBRP axelback exhaust that is throwing it off? Any help? Everything was installed correctly , made sure to disconnect the battery during installation to reset ecu
01-21-2020, 05:05 PM | #2 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
It's most likely your cai, axleback shouldn't effect anything. An easy check would be to put your stock intake on, reset the code, or unplug the battery for a while then drive around.
01-21-2020, 05:06 PM | #3 |
Yeah it was because I put the stock one back on and the code went away, no check engine light. So could it need a tune ? Maybe it throws the air/fuel ratio off
01-22-2020, 06:14 AM | #4 |
Yes, that cai will require a tune to run properly it appears. I believe it's about the maf sensor placement and different velocities of air throwing the sensor off.
01-22-2020, 06:28 AM | #5 |
You can advertise that intake in the Classified section here on the forum and buy a Roto-Fab or Cold Air Inductions Intake!
01-22-2020, 08:08 AM | #6 | |
Thank you Al Oppenheiser!
With any untuned CAI mod you run the risk of a CEL problem. Sorry to say Aggrsve_ss, but 99/100 the issue is the CAI (crappy air intake). The stock airboxes in our car do not need upgrading for performance if the rest of the engine up to and including the primary cats is still stock. The MAFs of our cars are very sensitive to airflow, and most CAIs on the market are not compatible with the stock tune and MAF setup on the car. This confuses the ECU, which throws a CEL and reduces performance, sometimes significantly. The two best options IMO for improving engine compartment bling w/o significant risk of screwing up your car are Rotofab (non-big gulp) or GM Performance intake. If your goal is performance, then you need to find a competent tuner first, then have a conversation about your budget and power goals to determine the best solution that meets your need for speed. So your options are:
01-22-2020, 11:37 AM | #7 | |
