07-06-2019, 11:23 PM | #323 | |
Drives: 2015 Corvette Stingray Join Date: May 2019
Quick question, I see you are SC; was your TB designed/made for a SC LT1 or LT4? Those little notches connect idle to power throttle, they are a "tunnel" that allow transitional airflow from the idling region to the power region. It is also missing any type of work at the outlet, an unexploited region by any other PTB and as effective as modifying inlet. We also feature a unique converging-diverging nozzle design that is formed between the blade chamfers (on what used to be sharp edges) and the body contour. This takes a long winded explanation but it accounts for quite a bit. We also, countersank the screws. Not much of a gain, we think, but a gain nevertheless. Lastly, you have nothing to lose. If you want to go back to your previous PTB, we'll refund you and give you a PTB of that brand. Thanks, |
07-06-2019, 11:27 PM | #324 |
Sorry, nothing yet. We appreciate you waiting for our product, but the way things are now (very busy w/ LT1/LT4) we don't see ourselves getting the LT5 design done and tested by next month.
07-06-2019, 11:28 PM | #325 | |
07-07-2019, 08:24 AM | #326 |
Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
Mike,
If I send in my TM PTB, what are the chances that I will NOT get your stated benefits:(Same as those of our SE8223-100 Premium Modified, Ported, and Calibrated Throttle Body (NEW). C7 LT1/LT4 Engines.) Due to it NOT being an OEM part? I have a semi new OEM TB with only 10miles on it, but I'd like to keep that should I need to take the car in for warranty work. I did have to do that once when I first installed the TM PTB, I was getting a CEL for rough idle at cold start up, so I changed out the TM for the OEM, which came with the car...turns out my #5 injector was bad however, the dealership installed a New OEM TB since there was a pin that was a little bent. I now reinstalled the TM and hence have a semi new OEM TB on the shelf. I'm not getting any CEL so I know the TM PTB was not part of the problem. I just don't want to send in the TM PTB and then NOT be able to gain the benefits as if I sent in an OEM TB. And as mentioned, I'd like to keep the OEM just in case I need to take the car in again for warranty work. I'm not trying to be difficult, just trying to figure out what would be best for my situation. Thank you!
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
07-07-2019, 08:27 AM | #327 | |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
07-07-2019, 10:14 AM | #328 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
Thankyou for the update and honesty!
07-07-2019, 12:16 PM | #329 |
Well since his website says they will re-work the TM, I thought I'd ask.
I can't see trying to sell the TM when someone asks why..."oh because I got one that I think is better." Especially if there's suddenly a lot of TMs being sold now. Or, I may just wait until my warranty is up.
07-07-2019, 12:34 PM | #330 | |
BL1ZZRD
07-08-2019, 12:33 AM | #331 |
Drives: 2018 Camaro 2SS Redline Join Date: Mar 2019
You can order one with out the engraving on the inside and outside. But if the dealer for some reason needed to replace your TB, you can always ask them for it back and see if they will. Or come up with some other reason to get it back. |
07-08-2019, 12:42 AM | #332 |
or just pay the extra $120 and keep yours. for warranty reasons. if they need to replace your tb no reason to get it back.
07-08-2019, 09:37 AM | #333 |
Drives: 2016 2SS M6 Join Date: Feb 2011
Similar to Dysan911's question above...........
How is this TB offering anything different than having more of a rev hang problem??- Having too much air through those extra notches when blade is closing, extra air the computer isn't programmed to burn, which is useful if you are going to KEEP accelerating/racing and shifting, but not useful if you are daily driving and need the rpm to come down nicely. I have the mamo PTB and I cant imagine any more air flow being beneficial. Who can clear this up?
2016 SS M6
07-08-2019, 10:04 AM | #334 | |
We always evaluate reworkability when receiving a PTB. In any case, if it goes wrong, we'll either, refund you and provide a used PTB of the same brand you had, or, provide a used SE TB. Always w/ a year warranty. You'll end up whole in the transaction no matter which option you go for. |
07-08-2019, 10:17 AM | #335 | |
We do not add more porting to other brands of PTB's, we think they got that pretty close to what it should be. That is, your gains start about 25%-30% thorttle, we bridge idle (<10%) throttle to what was already done to it at or above 25% throttle. Now your gains (response) will start right off idle. Don't have to wait to hit 25% throttle for the car to react to your input. We also convert the effective bore diameter from 87 mm to 91 mm for more gains (flow area) at WOT. There are many other little perks in there that add on to it. Like better surface finish, countersunk screws, etc. |
07-08-2019, 10:23 AM | #336 |
Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
Any videos of showing the performance of this new fangled product?
