02-14-2017, 12:26 PM | #15 | |
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
02-14-2017, 12:31 PM | #16 |
FMPG
Drives: 2016 2SS Join Date: Dec 2015
Sorry I couldn't help man. I only saw one pic in your post for some reason.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge 93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno) |
02-14-2017, 01:04 PM | #17 |
You're good. I'd appreciate any help at this point.
02-14-2017, 02:43 PM | #18 |
So I'm going to test that the orientation is the only problem by some creative wiring. Going to take apart an old fuse and just use the contacts to hold 2 separates wires in the fuse 51 slot. Then connect the wires in the correct orientation to the fuse tap. If that works I'll have to look into soldering the wires to the tap and mounting it somehow. It would be much easier to figure out if I can rewire the box to accept the fuse tap plugged in like I have it in the first pic. I've emailed the M2W guys twice but no answer.
02-15-2017, 08:43 PM | #19 |
Update:
So I tested the above wiring and confirmed indeed the fuse tap has to be installed in the specific orientation that is blocked by the K6 relay. So at least I've eliminated problems with the remotes and box itself. Now I'm looking at different solutions to running extension wires to the fuse tap. I'm wondering if using an inline ATP fuse holder connected directly to the #51 slot is the best choice. That way I can just plug the fuse tap into inline fuse holder, then solder the wires to the 2 contacts I removed from an old fuse. If anyone has any other ideas or suggestions feel free. I'm also in contact with the Mild2Wild guys to let them know of my findings. Attached is a pic of the "temp wiring" I used to verify everything worked.
02-16-2017, 01:13 PM | #20 | |
Drives: 2016 2SS Join Date: Feb 2010
why are you guys doing any wire splitting/splicing? As this video shows, its a plug n play operation (worked exactly as shown for me).
2016 Hyper Blue 2SS, A8, NPP, MRC
02-16-2017, 01:23 PM | #21 |
You didn't read or look at my pics did you? It would be plug and play if I didn't have a relay in the way.
02-16-2017, 03:20 PM | #22 |
I am wondering what the Mild to Wild does on the CA6 NPP. You can turn on stealth full time, even startup, and the fulltime sport/track sound mode the flaps only close on when you are cruising. Is the cruising open flaps the thing? Just wondering.
I have LTs/cats and the quieter cruising is nice with no drone in any mode.
02-16-2017, 03:29 PM | #23 | |
02-17-2017, 11:02 AM | #24 |
Update:
So big thanks to the M2W guys. They gave me an much easier workaround of using the fuse tap on another fuse that it will fit on (used the seat heater fuse which is 15A) and running the white wire to the negative terminal on the #51 fuse slot. Works perfectly now. I will take some pics and do a step by step write up here in case others with this mystery K6 relay need help.
02-17-2017, 03:40 PM | #25 |
Drives: 2018 ZL1 Garnet Metallic A10 Join Date: Feb 2016
I'm curious why you would need this when you can control the exhaust on the 8" display? You can have it open all the time or super quiet "stealth" mode. Am I missing something?
Buck
"I don't anymore, but I ustacould!" 2018 ZL1 Garnet Metallic |
02-17-2017, 03:50 PM | #26 | |
Sent from my SAMSUNG-SM-G920A using Tapatalk
04-08-2017, 06:52 PM | #27 |
Can you post those pics? I can't seem to get this to work on my car...
04-08-2017, 07:32 PM | #28 | |
*edit: the upload rotated the pic 90 degrees to the right FYI
