09-16-2013, 04:41 PM | #1 |
Drives: '10 Black/IOM Camaro SS/RS Join Date: Mar 2010
4th Gen Parts
http://ls1tech.com/forums/parts-clas...lq4-parts.html
Making room for another project. All parts are used unless stated as new and are sold as is. I can ship on Tuesdays and Fridays. Will knock price down if you are willing to pick up items. Will post pics between now and Sunday unless someone PMs me for a specific item. Parts are all located in Fayetteville, NC 28306. Prices with shipping are to lower 48 only. All truck / LQ4 parts have 62k miles. Please ask questions before buying 1. PRC Stage 2.5 5.3 heads (59cc) - $800 shipped. I purchased these used from a member on here about 4 years ago and I put about 8k miles on them. I had a machine shop replace one of the valve guides after a bent valve on the dyno (Loose rocker) and all miles were put on after that. Does not include springs, only the heads and valves http://www.texas-speed.com/p-1172-pr...ted-heads.aspx 2. 80lb Siemes Deka Injectors - $350 shipped. Sent to FIC for testing and flowing. http://fuelinjectorconnection.com/sh...hp?productid=9 SOLD 3. 30lbs Bosch Design III (36lb @ 58 PSI)- $150 shipped. http://fuelinjectorconnection.com/sh...p?productid=18 4. 98 Trans AM stock injectors - $50 shipped 90k miles 5. 4l60e - $150 picked up. Will deliver within reason for gas$$. 90k miles, been sitting inside garage since 2009 full of fluid. No known problems at time of removal 6. 4l60e Stock Convertor - $100 shipped 90k miles, been sitting inside garage since 2009 full of fluid 7. 2004 Truck intake w/rails and injectors. $200 shipped. 8. 2004 Truck Throttle body - $75 shipped 9. ARP HEAD STUDS 234-4110 NEW - $250 shipped. 10. ARP Head Bolts 134-3609 - $125 shipped. 8k miles 11. Stock 98 Perimeter Heads w/valve covers - $175 shipped. Stock valves and springs included but not assembled 12. 98-02 F body BBK Long Tube Headers w/Y Pipe, chrome - $200 Shipped Minor surface rust. 8k miles SOLD 13. 98 Trans Am Exhaust manifolds - $100 shipped 14. 98 Trans Am Stock Y Pipe w/Cats - $150 shipped 15. 98 Trans Am Rotors - $50 shipped 16. 98 Trans Am RED flat hood ,paint in good condition - $100 picked up or you arrange shipping 17. 98-02 Black Camaro RS Ground Effects (Sides and Rear) - $275 picked up 18. 78mm FAST Throttle Body (No sensors)- $125 shipped SOLD 19. Texas Speed 7.375 pushrods – $100 shipped / 8kmiles 20. Comp Cams 7.325 pushrods - $100 shipped / 5 miles 21. Stock 7.4 pushrods - $15 Shipped 22. 98-02 F Body ProBox (2 10” Subs) - $50 picked up only 23. 98-02 F Body stock eFans and shroud - $150 shipped 24. Huron Speed Alternator relocation brackets - $100 Shipped 25. Mike Norris Catch Can (Red) - $125 Shipped 26. 98-02 Camaro LeBra (blk) - $50 shipped / $35 picked up 27. 98-02 F Body Air intake base (non ram air). $50 shipped 28. Comp Cams Springs (26918) 5k miles $100 shipped 29. 04 LQ4 Coil packs and bracket - $85 shipped 30. 98-02 F Body SLP Air Lid - $65 Shipped 31. 04 Truck Oil Pan - $50 Shipped 32. 04 Truck Oil pick up and Windage tray - $35 Shipped 33. 2010 Camaro (Inferno Orange) Rally Stripes - New - $125 shipped http://www.revolution-motorsports.co...ally%20kit.htm Also have a 98 LS1 block, outer starter mount hole broke off, been using a nut on the end of a bolt for 3 years, no problem. #8 needs to be re-ringed getting a lot of blow by. Pics are big so you can see detail. Parts have not been cleaned yet, will cleanup before shipping. More to follow
2010 Camaro 2SS/RS Black/IOM //// 1998 Pontiac Trans AM 819 RWHP @ 12 PSI (Turbo)
10-21-2013, 09:54 AM | #2 |
Drives: 1989 camaro Join Date: Mar 2011
Best price plus shipping for the headers to a0e1e0 newfoundland canada? Thanks
