12-19-2021, 01:32 PM | #43 |
D3RPZILLA
Quick bump from the dead... seems they have some new revisions on some of their quick jacks.. and have many in stock. I went ahead and ordered the 7000TLX which seems like it should fit the ZL1 nicely (hopefully, lol) as well as a number of my other larger vehicles. Will post thoughts and video once received and setup and such and if I survive
Website: z1lla.com | YouTube: youtube.d3rpzilla.com YouTube Playlists: Performance Mods | Interior & Exterior Mods | Other Mods |
12-19-2021, 02:57 PM | #44 | |
Drives: Camaro 1LE Join Date: May 2018
12-19-2021, 05:52 PM | #45 |
Drives: 2021 LT1 Join Date: Aug 2020
Are the revisions/new models the "TL" series that gives you 3 inches more height?
12-20-2021, 11:41 AM | #46 | |
D3RPZILLA
https://www.quickjack.com/car-lifts/7000tlx/ From the site: Extended-length car lift design
02-22-2022, 09:14 AM | #47 |
This is a really good deal, 22% off.
07-30-2022, 10:34 PM | #48 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
One of my 7000slx frames is stuck and won't lower past halfway point between stop 1 and 2. My car is 1' off the ground and support doesn't open until Monday.
I regret this purchase.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
07-30-2022, 11:59 PM | #49 |
2020 Shadow Gray 2SS
Did you check the air charge in each unit? My SLX5000 has been flawless...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
07-31-2022, 12:53 AM | #50 | |
Yes, I read to try that in the troubleshooting, but they are now recommending that you don't even use the air cylinders. When I set mine up originally, I couldn't get the air cylinders to hold air, and support told me not to worry about it, that they don't recommend using them anymore.
07-31-2022, 01:06 AM | #51 | |||
07-31-2022, 01:25 AM | #52 |
I can't decide if I should wait until Monday and call support, or just use a jack and lift the car off the QuickJack and pull it out. I put jack stands in the front jack points and rhino ramps under the rear wheels in case one of the QuickJack frames should lose pressure overnight. I would hate for one of the frames to lose pressure, lower, and then drop the car off one frame of the QuickJack. I haven't been happy with the QuickJack at all. They seem to move when they lift and when it is lowered, the contact points move away from the jack points, and the heavy frame has to be re-adjusted. I have seen on the internet , people having trouble with cars falling off the rubber blocks, or the rubber blocks falling over. I wish I hadn't bought it.
07-31-2022, 03:08 AM | #53 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
I just recently purchased the 5000SLX. Manual says 40-50 psi air pressure and mentions this helps lower the jacks. I'm thinking you got some bad info, maybe a defective component. Use your good judgment, be careful and remember these things were made by our "good friends" in China!
07-31-2022, 12:52 PM | #54 |
Problem solved. One frame was either slightly crooked or slightly higher than the other frame. Maybe due to the crown of the drive way or maybe just weird asphalt spot. One frame would max out, but the other frame wasnt reaching max. That frame was not clearing the lock block. It was hung with weight still on the lock bar. I coaxed the UP button and got it to clear the lock block. At that point, weight was off the lock bar and I could lift it over the lock block. Car is down. Totally user error.
07-31-2022, 02:06 PM | #55 | |
07-31-2022, 04:41 PM | #56 |
Give speed a chance
Glad to hear your car is safely on all fours! You may want to take it out for a nice power ride to celebrate!
